#971 |
#973 | |
#974 |
#975 |
#976 |
Custom Title
Tough to make a joke on an international forum. Yes, that's the joke.
I write for www.enjoythemusic.com in the DIY section. You may find yourself getting a preview of a project in-progress. Be warned! |
#977 |
From ZenMod, yes it would have made me laugh my pants of, but it didnt
Well, Pano asked Last edited by tinitus; 8th December 2009 at 09:51 PM. |
#978 |
Oh, OK. Thought Earl might be talking about his Summas (he usually is) but wasn't sure it was a joke.
Well, if you haven't heard a well implemented A5, you might be surprised. I would be very interested to compare the Gedlee stuff. It certainly takes the right path. Anyone who has a pair is welcome to bring them over. I'd bring the Altecs to you, but they won't fit in the truck of my car! =)
Take the Speaker Voltage Test! |
#979 |
Which one? Sub out is LP at 80Hz imo. From the previous posts somewhere else I have got an impression that signal for SW must be driven from combined LCR.
Tomas |
#980 |
That is correct, you can do that with the DCX2496, although the center channel summation may be a little difficult. But L & R should be fine. Very few sources will have unique center LF. You can also make it "small" and that will route the lows to the L & R.
| Fitting drivers in cylinders pros & cons | 56oval | Multi-Way | 5 | 24th February 2009 01:30 AM |
| pros/cons of a 845 VS 211 | jarthel | Tubes / Valves | 2 | 18th June 2007 01:57 PM |
| TL vs MLTL, pros and cons | Tomac | Multi-Way | 5 | 29th December 2004 01:55 PM |
| Filterless DAC - pros and cons? | mr_push_pull | Digital Source | 1 | 11th August 2004 03:56 PM |
| Pros and Cons of this technique? | G | Tubes / Valves | 35 | 23rd October 2003 06:37 PM |
| Page generated in 0.10887 seconds (77.06% PHP - 22.94% MySQL) with 11 queries |
