#782 |
Like here Subwoofer testit - DVD Plaza Forums
Do pro drivers tend to have much lower hysteresis than hifi company (eg Seas, Peerless) drivers? I assume they do, but just thought I'd ask. Thanks |
#783 | |
#784 | ||
What do you mean bu "hysteresis"? in a loudspeaker? |
#785 | |
www.kta-hifi.net |
#786 |
I posted the link to subs only as an example, because they measure power compression
I'll quote something that explains hysteresis distortion: Hysteresis distortion implies that the system transfer characteristic is not always singlevalued for a given instantaneous input and will vary with both the change of direction and the level of the input and that it will therefore produce distortion that has a different phase to that produced by harmonic distortion. Hifi drivers tend to use very lossy surrounds compared to most pro drivers, which I assume introduces hysteresis distortion. Last edited by mattpwill; 22nd November 2009 at 09:47 PM. |
#787 | |
High sensitivity is essential Sure, low sensitivity combined with low power handling might be a real problem Even so, some of those seem to make many people happy nonetheless Expectations to SPL would be a major player btw, In my youth I accidentally put full supply power into my Lowther fullranges, due to some amp malfunction ALL of the voice coil wire was literally thrown out of the gap, in a messed up bundle hanging in front of the drivers Funny "picture", but it wasnt much fun when it happened I cant bare the thought of owning the exstremely expencive Feastrex drivers, and always have to fear the moments(rare) with alcohol on the table Last edited by tinitus; 22nd November 2009 at 09:54 PM. |
#788 | |
I've experienced blown tweeter by old leaky filter caps in ancient tube amp. I was in another room and heard suspicious noises, like some muffled fireworks. It was odd that the noise was not loud, and there're output transformer and series cap before the tweeter. One of the tweeter was still blown. |
#789 |
#790 | |
I am not even sure that I could design one that had significant amounts of hysteresis let alone it happening naturally. |
| Fitting drivers in cylinders pros & cons | 56oval | Multi-Way | 5 | 24th February 2009 01:30 AM |
| pros/cons of a 845 VS 211 | jarthel | Tubes / Valves | 2 | 18th June 2007 01:57 PM |
| TL vs MLTL, pros and cons | Tomac | Multi-Way | 5 | 29th December 2004 01:55 PM |
| Filterless DAC - pros and cons? | mr_push_pull | Digital Source | 1 | 11th August 2004 03:56 PM |
| Pros and Cons of this technique? | G | Tubes / Valves | 35 | 23rd October 2003 06:37 PM |
| Page generated in 0.13311 seconds (80.08% PHP - 19.92% MySQL) with 11 queries |
