#771 |
Custom Title
I was windering that too!
In all seriousness, though, pro stuff DOES seem to do dynamics quite a chunk better. And with todays compressed recordings, we need every bit of help we can get!
I write for www.enjoythemusic.com in the DIY section. You may find yourself getting a preview of a project in-progress. Be warned! |
#773 |
Speakerholic
Grunt!
Me like'm big & heavy Me like'm 4" aluminum 4 layer coils and rugged composite cones. Me like'm big horns. Big horns = Big music Me no like'm sissy hi-fi drivers - those for my sister. Grunt. Must go drink grog now. Cheers. |
#774 |
#775 |
Actually, the plan is to build Rubanoides together with a friend
Yeah, I suppose I will use 18" woofers ![]() In the meantime I will play with some planar designs Pro or hifi, I have no idea, and really dont think about it Last edited by tinitus; 22nd November 2009 at 05:52 AM. |
#776 | |
My only other contribution to this thread will be that although Tonality goes a great way to selling the illusion without Dynamics though it has no hope of passing off the illusion as the real thing. Dynamics IMO is probably the most important part to making the illusion seem like the real deal. Please note though that Dynamics does'nt always mean high levels of average SPL, you can have dynamics at low levels and high levels. |
#777 | |
And thats why i like this forum, since we dont forget to have fun with our hobby. |
#778 | |
#779 | |
#780 |
On the issue of dynamics I think lower efficiency drivers are simply on the wrong side of the power curve and more importantly are not designed to handle the power required for them to reproduce the loudest peaks. If they cannot do that them obviously music reproduced using them will be compressed. In addition to the driver issues lower efficiency speakers tax the amp speaker combination to it's limits much more easilly.
If you take a 85db speaker move back 12 ft you would be lucky to get 105db from the pair with 100 watts where you listen. That sounds like a rather high SPL level but it's not with a well recorded music where the dynamics are properly recorded. A snare drum rim shot could get you there in a heart beat, even playing at a more modest 85db average. I think Earls right we need a Dynamic Linearity test to really see what's happening. Rob
"I could be arguing in my spare time" |
| Fitting drivers in cylinders pros & cons | 56oval | Multi-Way | 5 | 24th February 2009 01:30 AM |
| pros/cons of a 845 VS 211 | jarthel | Tubes / Valves | 2 | 18th June 2007 01:57 PM |
| TL vs MLTL, pros and cons | Tomac | Multi-Way | 5 | 29th December 2004 01:55 PM |
| Filterless DAC - pros and cons? | mr_push_pull | Digital Source | 1 | 11th August 2004 03:56 PM |
| Pros and Cons of this technique? | G | Tubes / Valves | 35 | 23rd October 2003 06:37 PM |
| Page generated in 0.12742 seconds (77.24% PHP - 22.76% MySQL) with 11 queries |
