#681 |
Custom Title
My own experimentation with long-term DBT proves otherwise. I found much higher rates of successful identification within a casual listening, long term, home environment than is seen in the studies you reference. Requires a 'blind' switchbox and notetaking, but for me it was more than sufficient to show that the short term tests used are insufficient for all but the highest level effects.
Again, I'll point out- there have been DBTs conducted where the listeners didn't have any statistically significant identification of significantly different speakers. A lack of system familiarity is a biggie, we're dealing in subtleties in hifi anyway. Your typical DBT eliminates the ability of someone to focus on what changes have been made to the system they know and love. So they're hit with a large amount of unfamiliar information and forced to choose, when you're testing for subtleties. Seems pretty obvious to me that the test method would often swamp the test subject.
I write for www.enjoythemusic.com in the DIY section. You may find yourself getting a preview of a project in-progress. Be warned! |
#682 |
#683 |
Hello,
Has anyone had experience with the AE TD15M in a two-way with horn loaded compression driver? After many comments regarding the AE woofers as being one of the best professional designs around. I thought the TD15M as being a good candidate to use as a monitor designed around its strengths with a four distributed subwoofer set up? Thanks for any input. NW |
#684 | |
There're a couple of studies that showed that there is no audible difference under anechoic conditions when the loudspeakers had similar on-axis frequency response. Whereas in rooms speaker directivity plays a major role. Differences became audible. Flindell et al. "Subjective Evaluations of Preferred Loudspeaker Directivity" - AES E-Library: Subjective Evaluations of Preferred Loudspeaker Directivity Best, Markus |
#685 | |
#686 | |
I would really like to hear higher audio quality in the digital realm overall - maybe enough to get refractory when discussing low end lossy digital audio formats - my DVDA and SACD collection is of high enough SQ in general that I wouldn't miss new releases in analog too badly if such was the minimum digital audio standard. |
#687 | |
#688 | |
What a lot of people don't understand is that sound quality would even exist if there was no music at all. Best, Markus |
#689 | |
#690 |
Actually, I meant THIS site, but sure, it's probably true of the Stereophile guys. Non-humans, with computers instead of carbon-based brains.
“Listening to records is like ****ing a picture of Brigitte Bardot.” - Sergiu Celibidache |
| Fitting drivers in cylinders pros & cons | 56oval | Multi-Way | 5 | 24th February 2009 12:30 AM |
| pros/cons of a 845 VS 211 | jarthel | Tubes / Valves | 2 | 18th June 2007 12:57 PM |
| TL vs MLTL, pros and cons | Tomac | Multi-Way | 5 | 29th December 2004 12:55 PM |
| Filterless DAC - pros and cons? | mr_push_pull | Digital Source | 1 | 11th August 2004 02:56 PM |
| Pros and Cons of this technique? | G | Tubes / Valves | 35 | 23rd October 2003 05:37 PM |
| Page generated in 0.14422 seconds (82.03% PHP - 17.97% MySQL) with 11 queries |
