Old 16th November 2009, 06:25 PM   #491
Originally Posted by 45 View Post
I wrote that I don't buy digitally mastered vinyls.
No, you didn't. I asked you where to buy "digital free" LPs. You answered "Because it didn't exist!". So I concluded that you must be buying stuff that is older than about 30 years. I asked a simple question you responded with something that can't be called an answer.
I know what I buy if you don't it's not my business.
You just look for flames every time.... Are you frustrated or envious? If not just don't quote my messages and I will not waste my time in replying. Because it is a waste of time, IMO.
I only get frusted when someone insults me or is making false statements without having a single argument.
If discussing a topic is a waste of time for you then why did you join this forum? Makes no sense.
Best, Markus
Old 16th November 2009, 06:47 PM   #492
Originally Posted by thoriated View Post
Dolby AC-3 allows only a MAXIMUM of 640Kb/s, often as low as 320 Kb/s for FIVE full frequency response channels plus the Subwoofer channel, lower than most MP3. That's pretty far short of 'high SQ' , in my book. OTOH, a set of Bose Cubes aren't the best way to evaluate HT SQ in the first place.
Get the facts right. Blu-ray allows for Dolby Digital at 640 kbit/s, Dolby Digital Plus at 1.7 Mbit/s and Dolby TrueHD at 18 Mbit/s. Here's what actually can be found on Blu-ray: Technical Statistics Page - Blu-rayStats.com
The music industry doesn't deliver that kind of quality. I only know one exception: http://aixrecords.com/
Best, Markus
Old 16th November 2009, 07:11 PM   #493
Kevin the fact is that the present AD/DA process is not good enough to match vinyl as a rule.
Good afternoon 45,
As I understand it the sampling rate for the standard audio CD is around 44 kHz. The Nyquist theoretical maximum encoded frequency would then be just under 22 kHz. Certainly, we have enough sampling to resolve 20 kHz. Does a true analog source like vinyl really have an advantage here?
Old 16th November 2009, 07:15 PM   #494
The music industry doesn't deliver that kind of quality. I only know one exception: AIX Records - Audio Fidelity Beyond Reality
Best, Markus
This is along the lines of what I was just talking about with 45. Those kinds of sampling rates are not needed for reproduction of the audio spectrum. It's just wasted - bigger numbers in this case don't mean better. Those media formats require that kind of data throughput largely for high-resolution video, which is far more data intensive than even multiple channels of audio. I don't think in this case, quoting 'performance' numbers such as those are really applicable.
Old 16th November 2009, 07:31 PM   #495
45 is offline 45  Italy
45's Avatar
Originally Posted by J.R.Freeman View Post
Good afternoon 45,
No. It's just theory. In practice I can't see a device that can work without dithering and/or noise shaping i.e. artificial modification of the time sequence of the samples (because you cannot know what kind information you are removing a priori).
This is by far the worst limitation of digital devices. In principle 44.1 KHz could be enough in practice they are not. At least until they don't sort out the above problem.
In an analogue recording the time sequence is not manipulated. In the worst case you can talk about phase but, remaining time continuous, you have the tools to deal with it.
Old 16th November 2009, 07:34 PM   #496
Get the facts right yourself, Marcus. Obviously you missed the fact that what I was discussing is Dolby AC-3, the DOMINANT (and default for DVD) audio coding scheme for video discs in the real world and, by the way, rebutting dishonest sales pitches hyping the sad SQ that actually exists on most DVDs and BDs.
Old 16th November 2009, 07:41 PM   #497
CD4 vinyl was cut to 45khz. So, unless you believe brick wall filters at 20khz are perfect, I guess the answer would be 'yes'.
Old 16th November 2009, 07:53 PM   #498
Yes but Thoriated, perhaps I am missing the point - but we can't hear frequencies that high. Is extension to 45 kHz an advantage?
Old 16th November 2009, 07:56 PM   #499
cbdb is offline cbdb  Canada
these are not timeing errors, sure your not thinking of jitter?
IMO the worst part of vinyle is the wear of production devices, mainly the stamp, but also the lath cutting head. Every time a piece of vinyl is pressed the stamp wears a little, when you buy an LP you dont know if it was pressed at the begining or end of the stamp life, with each consecutive pressing deteriorating.
Old 16th November 2009, 08:08 PM   #500
I agree that DVD multichannel AC-3 is inferior to 2 channel PCM but that's not the point. The original sound recordings for movies are as good (or bad) as music productions. Blu-ray is available and offers equal or better resolution than CD and all the great benefits that additional channels can deliver. There's no need for anybody to get a DVD with AC-3. The music industry could deliver that kind of quality level too but they just don't care because the consumer doesn't care. Otherwise iTunes would offer uncompressed downloads. Apple lossless is around for years.
Best, Markus
Fitting drivers in cylinders pros & cons 56oval Multi-Way 5 24th February 2009 01:30 AM
pros/cons of a 845 VS 211 jarthel Tubes / Valves 2 18th June 2007 01:57 PM
TL vs MLTL, pros and cons Tomac Multi-Way 5 29th December 2004 01:55 PM
Filterless DAC - pros and cons? mr_push_pull Digital Source 1 11th August 2004 03:56 PM
Pros and Cons of this technique? G Tubes / Valves 35 23rd October 2003 06:37 PM
Page generated in 0.12995 seconds (79.63% PHP - 20.37% MySQL) with 11 queries
