#401 | |
As too how much "dynamics" is needed, the speaker should never be the limiting factor in the dynamics if accurate playback is desired. Once you live with a speaker that has superior dynamics, everything else sounds compressed. No matter what the SPL. |
#402 | |
There is nothing like having properly designed speakers without limitations. |
#403 | |
THanks for the model number, I know all about Zaph's site, I bought half the drivers listed on it (I use the B&C 6MD38-8 AND 18sound 6ND drivers over the scanspeak drivers) . but you are misquoting me on saying it sucks. I posted that is sucks with respect too Dynamics compared to the TD12M woofer that John builds over @ Acoustic Elegance and no one can argue that point. You even proved it by having to add more drivers. You will not get a disagreement out of me that multiple drivers of anything will have dynamics....line arrays are sweet!! The biggest problem with your mulitple driver for sensitivity theory is that you then need a ribbon tweeter to match the sensitivity or some shallow waveguide for the dome tweeter to increase its sensitivity. Hmmm....Maybe I will buy 4 Revelator 7" drivers and use my extra Neopro5i ribbons I have unused. Then compare against my Neopro5i/PHL1120/TD12S custom design. I have had the big towers with multiple 6 and 8" drivers and still the performance of the single 12" or 15" pro audio higher end driver is incredible. Have you even had a chance to listen to speakers with such drivers? I would hope anyone posting in this thread have listened to both. Last edited by doug20; 13th November 2009 at 02:17 PM. |
#404 | |
Any expert speaker builder I know of never concern themselves with simple on axis FR plots. Im no expert in building DIY speakers but I read enough and learned enough over the past many years to now know FR response isnt important actually compared to other measurements. Great sites like Zaphaudio.com have great measurements that people can get into the last one I ever look at is the FR plot. Too bad Zaph has went commercial so we won't see future measurements, except his own drivers
#405 | |
Several times people have posted that its all about the specific requirements for me the scanspeak will not meet my requirements, for you it does. Of course the best nearfield monitors I have heard are built by Genelec |
#406 | |
Best, Markus |
#407 |
#408 | |
#409 |
#410 | |
I can see the point about a single on axis measurement having little value. You should really measure is several locations in your chosen "window" to get a more meaningful idea of what the speaker is really doing. I am a little perplexed that you feel FR is not important? What measurements are more important in your opinion?? When I do my own DIY I look at the Step Response, CSD, and FR but I weigh the FR as a very important indication that I have my passive crossovers summed properly and my octave to octave tonal balance will be correct. I use mostly Pro Drivers and many of mine are dual use and have been used in both Pro and Commercial applications. Rob
| Fitting drivers in cylinders pros & cons | 56oval | Multi-Way | 5 | 24th February 2009 01:30 AM |
| pros/cons of a 845 VS 211 | jarthel | Tubes / Valves | 2 | 18th June 2007 01:57 PM |
| TL vs MLTL, pros and cons | Tomac | Multi-Way | 5 | 29th December 2004 01:55 PM |
| Filterless DAC - pros and cons? | mr_push_pull | Digital Source | 1 | 11th August 2004 03:56 PM |
| Pros and Cons of this technique? | G | Tubes / Valves | 35 | 23rd October 2003 06:37 PM |
| Page generated in 0.15345 seconds (82.16% PHP - 17.84% MySQL) with 11 queries |
