#341 |
Here is a measurement. My own measurements show the same.
As for bats, according to Wikipedia (couldn't find any other information about it, lazy searcher as I am), their echolocation range is primarily limited by their pulse interval, not air absorption. To clarify further, I don't believe in super-hyper-tweeters also, I agree that importance of frequencies above 10 kHz falls (for humans and their music, anyways). But I wouldn't say that those frequencies are absent in nature - I have fooled around with a bat detector outdoors, it was quite fun to hear all this ultrasonic noise. Up to around 30 kHz it's quite busy (crickets, grass and leaves moving in the wind etc), after that it gets increasingly quiet. |
#342 |
My wife teaches Audiology and she told me that nob ody does tests above 8 kHz, that the standard is only defined to 8 kHz and she showed me the form, which only went to 8 kHz.
#343 | ||
Please don't misquote me, or let me correct any misunderstanding, its not that no animals or signals use the frequency band above 10 kHz, its simply that with the large air absorption, those frequencies are very limited in scope. Humans deal on a very large distance scale compared to say a small cat. Cats hear well above 20 kHz, but on their distance scale the absorption is not a big factor. For humans it is. It's all a matter of degree. Signals exist, we can detect them, but our hearing is ill equiped to utilize them to any significant degree. The obviuos reason is that there has been no evolutionary development of these frequencies because of their rarity over larger distances in the environment. Our hearing is amazingly precise in all those attributes that nature dictates would be important for survival. Above 10 kHz is NOT one of those. |
#344 | |
Your quick answer about the 15" woofer having problems before 1200Hz is incorrect. You just need to realize what some QUALITY woofers can do! Linearity is incredible, distortion, extremely low and its just below the point of beaming. Your post is a great example of over simplification. You haven't seen some of the better drivers and you might be assuming your needs are paramount. Some of us require dynamics without compression and distortion and some of us do have bigger rooms then a shoe box too! HiFi drivers can not do that period so they are of a lessor quality then other choices like quality built pro audio drivers. Last edited by doug20; 12th November 2009 at 02:27 PM. |
#345 | |
Best, Markus |
#346 |
Slightly OT- there's some literature on the range of bat echolocation (I can post cites if anyone is interested). One factor on why the range is surprising is the astonishing SPL that the bat can produce; these have been measured as 120-133dB!
"...we stumble and get up, we are sad, confident, insecure, feel loneliness and joy and love. There is nothing more; but I want nothing more.” - Christopher Hitchens 1949-2011 |
#347 |
That most modern recordings are extremely poor is true, but really great ones do exist. I find the artists who care about their art care about how it is reproduced. One exception that I found was a terrible recording of Linda Ronstadt whom I have always had great respect for. How she allowed such a flawed recording to get out is truely a mystery to me. It may well be that she doesn't even know. Lets hope that someone actually realizes this and tthat the quality control has not degraded to the point where bad recordings get distributed without anyone even realizing it.
#348 | |
Pink Floyd "Money" ![]() Metallica "Frantic" ![]() Roxy Music "Avalon" ![]() Bob Dylan "Thunder on the Mountain" ![]() Best, Markus Last edited by markus76; 12th November 2009 at 03:11 PM. Reason: Added examples |
#349 |
That explains a lot!! Quite consistant with the kind of loses that I was describing. 120 dB out, -60 dB attenuation traveling through the air, 60 dB returning to the bat. Not a problem. For humans, 20 kHz at "normal" levels of say 80-90 dB and a distance of say 10->20 meters and you have 50->60 dB - not audible for most people in most environments.
#350 |
What do you base that comment on. Do you have evidence that this is the case? I put it down to distribution where the maximum perceived loudness is felt to be the most desirable attribute and that the lower sound quality that results is recognized as "unfortunate" but completely accepted as a "trade-off" to making more money. In other words they know precisely what they are doing and accept it as OK. This was the situation with "quality" at the car companies when I started. They knew exactly how bad the cars were, but they didn't care. Poor quality made more money.
| Fitting drivers in cylinders pros & cons | 56oval | Multi-Way | 5 | 24th February 2009 01:30 AM |
| pros/cons of a 845 VS 211 | jarthel | Tubes / Valves | 2 | 18th June 2007 01:57 PM |
| TL vs MLTL, pros and cons | Tomac | Multi-Way | 5 | 29th December 2004 01:55 PM |
| Filterless DAC - pros and cons? | mr_push_pull | Digital Source | 1 | 11th August 2004 03:56 PM |
| Pros and Cons of this technique? | G | Tubes / Valves | 35 | 23rd October 2003 06:37 PM |
| Page generated in 0.12948 seconds (87.59% PHP - 12.41% MySQL) with 11 queries |
