#21 | |||
The question of the original poster did not sound very 'scientific' to me, therefore my answer start with "I guess", but I will remember to ask you first, next time, if I may respond to someones question. Quote:
#22 | |
#23 | |||
I do both, I listen and measure...You do not measure so your subjective listening experience is tainted with BIAS and your opinion would be invalid when we are talking about the true performance of any driver. For all you know you might like distortions and inaccurate drivers because you posted that you have little scientific knowledge and it sounds like you never measure anything. This is DIY where speakers are built based on measurements and science...listening is just a part of the equation. You can not post opinion just becuase you think you have a golden ear Quote:
Do you measure drivers? Do you understand how drivers are built? As for speaker names...JBL K2, Geddes Summas, Anything Tom Danley makes (Have you heard those? If I could only get a new demo pair (SH-mini) in house!!! ), Many Genelec speakers...the list is pretty big. I would take them over any boutique hi-fi speaker that does not measure as well meaning they suck for the performance I require. My HT theater demands the best speakers! |
#24 | |
Many are building HT speakers with pro-audio drivers these days. AE speakers has some of the best pro audio woofers around (like the TD series), I believe they are better then any other options in the same price range, I do not know of a 8" or 6" driver that can come even close to the TD12M or TD12S performance. btw, what was the clear winner for you? Could you name the products demoed? I want to get the Danely SH-100 or SH-mini in house but I can not find a local dealer and no response back with I emailed Danley. I have cust DIY speakers with (Neopro5i, PHL1120, TD12S) I want to see how the Danley designs compare...I also have NHT speakers, AV123 speakers and older PSB speakers. None of them come close to my custom DIY speakers in terms of dynamics and details but none of them have ribbon tweeters either. |
#25 | ||||||||
Oh, I like distortions and inaccurate drivers, I will ask Seas to improve their Excel range because you say so. Quote:
#26 |
point by point response, yikes!!....okay you win
Okay, you think this is only bout music have you read about Geddes Summas? You read about he measurements and the performance....give me a hi-fi speaker that does what they do. They are pro-audio designs. As for the person wanting to argued I never posted false information about pro audio drivers saying their are heavier then hi-fi...you did and I called you on it asking for some valid proof. If you can not back up your bold statement with proof I would suggest you not post it in the first place. No arguements needed just proof would be welcome. DIY does have sciences to it and with that if you are going to post BOLD statements about how hifi drives are superior to pro audio please back up that subjective opinion with specs and measurements. I always love to learn something new but at this point, depending on the requirements pro audio drivers are better. Hifi / Home Theater......there is a difference? There are non-hi fi drivers out there....Seas drivers are not used in Home Theater??? Stop being so exlusionary and expand you mind. |
#27 |
Everything evolves. ProAudio may have started out aiming to be efficient and rugged but along the way as improvements are made their accuracy and detail can be improved without affecting their main goal.
I have a pair of Selenium 15PW3-SLF 15" woofers, 98dB efficient and sound wonderful thru the volume range and can really hammer with only ~85watts per. |
#28 | |
The measurements on the TD drivers from AE speakers are incredible. Someone else posted something about ragged response but I do not see that in some of the recent pro offerings. I think its great to have 95dB speakers, small amps and the ability to hit 120dB is important to me. Im not a 2-channel critical listener that sits in a middle of a room with two speakers in front of me...that is not remotely my world. |
#29 | |
There was demand for compact speakers delivering as much of the audio spectrum. This was at the cost of efficiency. Since there is (usually !!!) not much demand for high SPLs in a domestic environment the average listener could live with that. Many modern PA drivers are of high quality nowadays. You can build high quality home systems with these and take advantage of the fact that you (usually !!!) run them at power levles that makes them barely move. Therefore they sound very effortless and dynamic. I have a system that I listen to once in a whil and which is great fun to crank. It uses a 12" JBLK woofer and bi-radial tweeter. But it is definitely larger than my other system that I use mostly. The main disadvantage of using PA drivers is indeed the system size (specially when you want to go low) - here the usual HiFi systems have their advantage. Remember that it doesn't make sense to listen to hugeh systems close-up in small rooms. Driver integration would be much bettter with a small system using typical HiFi drivers. Regards Charles |
#30 | ||
There is certainly a lot more to Earl's designs than just the use of pro drivers, but there is such a clear advantage in my opinion w/ regard to dynamics that I don't ever see myself resorting to hifi drivers again. These speakers changed my definition of "rocking". I'm hoping to play with some more waveguide/pro-woofer combos in the future. I've got some QSC waveguides on my workbench and the TD15M is looking pretty appealing.
Mobile Sound Science |
| Fitting drivers in cylinders pros & cons | 56oval | Multi-Way | 5 | 24th February 2009 01:30 AM |
| pros/cons of a 845 VS 211 | jarthel | Tubes / Valves | 2 | 18th June 2007 01:57 PM |
| TL vs MLTL, pros and cons | Tomac | Multi-Way | 5 | 29th December 2004 01:55 PM |
| Filterless DAC - pros and cons? | mr_push_pull | Digital Source | 1 | 11th August 2004 03:56 PM |
| Pros and Cons of this technique? | G | Tubes / Valves | 35 | 23rd October 2003 06:37 PM |
| Page generated in 0.17409 seconds (85.14% PHP - 14.86% MySQL) with 11 queries |
