#221 | |
The thing about a real piano in the room is that the sound comes from the a large 6 or 7 foot wide space, not a point. So my "piano speakers" would be placed no more than 6 feet apart in the center of the room ad be omni-directional. Then just like a real piano a listen could walk in a circle around it. I think this is the only way you'd ever hear a recording that sounds "real". Here is another un-related idea.... Frank Sinatra invented a kind of vocal sound that could not be heard prior to recording. It is common now. He sang at very low volume into a mic that was very close. Before singers were told to "project" their voice so they could be heard in a large venue. Recording changed that. So even voice is really like an electric guitar in that what you hear is the sum of the voice, mic, effects (reverb, EQ,..) and the amp and speaker. Even a nylon string classical guitar is mic'd if it is on CD. And it's typically mic'd in a way that is not the same as you'd hear it. The engineer will place one mic near the sound hole and typically another a foot or two back and mix them Even jazz recording from the 50's done with analog tape. The recording engineer used multiple mics and mixed them, thereby creating a sound you could not have heard if you were in the room |
#222 | |
Imagine two 15" drivers on a 16" baffle. How much baffle area is left? Think cone area vs. baffle area. |
#223 |
And the other sides? The medium-low frequency response will be inevitably more influenced by the room in comparison to smaller enclosures. This is the point where I make my choice: the smallest overall surface (i.e. volume enclosure) that gives me the best compromise between minimal interaction with the room and good response.
#224 | |
I have always wanted to see the measurements comparing the two since subjectivity is a waste of time to debate. |
#225 | |
I did the hifi stuff for years and thanks to researchers like Geddes I have found my way to something better. DIY can not be more exciting right now.....Yeah, I should send Geddes Royalties
#226 |
Thanks for the response.
![]() BTW, although the little amp is (maybe) rated 0.7w, the pre amp can drive it slightly into class A2 and squeeze some more power
#227 |
I thought that Bing Crosby was the pioneer of that technique. No?
Take the Speaker Voltage Test! |
#228 | |
#229 |
#230 | |
I'm just not sure that is the entire story, carried to an extreme in my experience this just results in what sounds like a pair of (perhaps good) speakers playing into a room and being overwhelmed by it as opposed to some much larger speakers that just seem able to disappear - generating a much more convincing sounding performance. I admit I may have missed your point, but I guess I am just a BIB type of guy with those 11 cu ft Onken enclosures with 16" woofers in my modest sized listening room. (JBL horn mids and tweeters - 300B SE power) Sonically they almost disappear on some material and it is scary - like nothing I have ever heard from a more modestly (sanely) sized system.
www.kta-hifi.net |
| Fitting drivers in cylinders pros & cons | 56oval | Multi-Way | 5 | 24th February 2009 01:30 AM |
| pros/cons of a 845 VS 211 | jarthel | Tubes / Valves | 2 | 18th June 2007 01:57 PM |
| TL vs MLTL, pros and cons | Tomac | Multi-Way | 5 | 29th December 2004 01:55 PM |
| Filterless DAC - pros and cons? | mr_push_pull | Digital Source | 1 | 11th August 2004 03:56 PM |
| Pros and Cons of this technique? | G | Tubes / Valves | 35 | 23rd October 2003 06:37 PM |
| Page generated in 0.13110 seconds (85.89% PHP - 14.11% MySQL) with 11 queries |
