Old 14th July 2009, 07:16 AM   #1
Default Ideas of old Linn Keilidh cabinets?
I have purchased a pair of empty Linn Keilidh cabinets. These are infinite baffle floorstanders with two 6" (tbc) drivers and a tweeter in MTM configuration.
Any ideas on a good solution for drivers and crossover? I've had a couple of ideas...
I have a huge Dayton sealed sub that covers the low end nicely, so I considered going for a high sensitivity design with Fostex full rangers and an FT17H tweeter. In a sealed box the speakers would probably do nothing below 100Hz, but the sub would cover this area so no probs. In fact, maybe I could get a good result with speakers naturally rolling off pretty high allowing the sub to cover the lowest regions on its own.
The other idea I considered was a design influenced by the excellent Living Voice OBXRs.
Any thoughts?
Old 14th July 2009, 11:18 PM   #2
choosing appropriate drivers depends on the internal volume (35-40L?), and your budget...
‘today… there lives alongside the twentieth century the tenth or thirteenth. A hundred million people use electricity and still believe in the magic power of signs and exorcisms” Trotsky
Old 15th July 2009, 01:16 AM   #3
jackinnj's Avatar
fwiw, I am still using Kelidh's in my Den -- biamped. They are "a pointe" for the space.
Old 15th July 2009, 02:08 PM   #4
I received the first cabinet today and measured the drive unit cutouts. The bass driver hole is perfect for the Eminence Alpha-6A and Alpha-6C, which would seem to be excellent low-cost high-efficiency candidates. The tweeter hole is a about 2mm larger than required for the Fostex FT17H - I have been keen to try this tweeter for a while and it would work well with the Eminences...
Fostex FT17H
Eminence Alpha-6A
Eminence Alpha-6C
Any suggestions for passive crossover type?
Linn Lk1 dw887 Solid State 13 6th April 2010 10:58 AM
Linn LK-1 angel007 Solid State 1 2nd February 2010 10:31 PM
FA UK Linn Kan Mk1 mr-mac Swap Meet 0 4th August 2008 09:12 PM
ideas for my empty Skyline Cabinets punkrokr1701 Multi-Way 4 23rd January 2007 03:44 PM
WANTED Linn Keilidh bass/mid driver klc-audio Swap Meet 0 25th August 2006 11:01 PM
Page generated in 0.07243 seconds (70.32% PHP - 29.68% MySQL) with 10 queries
