diyAudio
diyAudio (http://www.diyaudio.com/forums/)
-   Multi-Way (http://www.diyaudio.com/forums/multi-way/)
-   -   Seeking pics of your input boards (http://www.diyaudio.com/forums/multi-way/147469-seeking-pics-your-input-boards.html)
ro9397 14th July 2009 03:58 AM
I would be indebted to see pictures of your input terminal boards on your finished speakers, to help me decide what to employ on my own.
TIA!
Dr_EM 14th July 2009 11:30 AM
I don't think this is quite what you're after as it's not yet installed on a finished speaker, but I had it to hand. 2 sets of connections, for active midrange and tweeter with 6db filter for protection. Large connection plate, did have foam sealing gasket but I didn't want it in this application, mounted my "crossover" board with threaded nylon hex standoffs and bolts :)
http://img200.imageshack.us/img200/6...onnection1.jpg
http://img263.imageshack.us/img263/5...onnection2.jpg
Inductor 14th July 2009 01:36 PM
2 Attachment(s)
inputs pic
ro9397 14th July 2009 07:40 PM
Thanks! Keep em comin!
Your pictures are requested in case something catches my fancy to replace the current plan to cut a hole fitting the ubiquitous large plastic terminal cup, about 3.5 x 4.25". Only because of a cosmetic aversion to the plastic cups, an MDF terminal board of 1/2 or 3/4" thickness will be attached to the inside rear panel.
Will shortly post a picture of the binding posts employed on my favorite OEM standmount speakers, toward the goal of discovering the binding post brand & model.
Thanks again for your help.
Inductor 7th August 2009 02:01 AM
(This) Also look nice
http://www.visaton.de/en/chassis_zub...ehoer/277.html
Copyright 1999-2017 diyAudio
