Old 10th July 2009, 07:58 PM   #1
gorvann is offline gorvann  United States
Question Matching a sub to a prebuilt ported design
How do you match a sub to an already bulit ported box cabinet?
I have some old loudspeaker cabinets. A three way design that has the port already installed. I dont have the orignal drivers. I like the cabinets and want to install new drivers and crossovers.
Any help on this would be gladly accepted.
Old 10th July 2009, 11:11 PM   #2
Within certain limits, the cabinet and port are independent of the speaker. The volume of the cabinet combined with the diameter and the length of the port cause the box to resonate at a particular frequency.
There are different schools on where that resonance frequency should be, but in general, it should be roughly near the Fs resonance frequency of the speaker/driver itself. In that sense, the cabinet and driver are connected.
Measure or estimate your cabinets internal dimensions and convert it to either square feet or Liters. Next determine the ports inside diameter or dimensions and its depth.
Then use one of these port calculators to determine the resonance frequency of the box. Remember to subtract some internal volume for the space that the driver takes up.
http://www.2k4civic.com/portcalculator.html
http://www.linearteam.dk/default.asp...ventcalculator
http://www.carstereo.com/help2/Articles.cfm?id=31
Set the volume and the port information, and determine the tuning frequency.
The other factor to consider is that different drivers are optimized for different sized boxes, though there is some flexibility. This is somewhat determined by the Vas specification of the driver.
Also, you need to determine whether the driver is more suited to a seal cabinet or a vented cabinet.
To get this, you divide the Resonance Frequency (Fs) by the Electrical 'Q' factor (Qes) or (Fs/Qes). If the number is 50 or less, then a seal enclosure. While a value of 100 or more suggests a vented enclosure. Anything in between is a judgment call.
Steve/bluewizard
Old 11th July 2009, 12:13 PM   #3
What is the brand of the loudspeaker cabinets? If you have the make and model it is possible you can get replacement drivers or much superior drivers based on cabinet size.
If custom made, measure the inside dimensions and post them as I'm sure the volume and port size will inspire folks here to recommend various drivers that will work in such a space. Also describe if there are seperate compartments for the mid and tweeter or if it is just one big box with everything in it.
Are you willing to modify these cabinets some if necessary? Nothing major and probably just inside which won't be seen anyway.
Oh yeah, what is your budget?
Old 11th July 2009, 01:19 PM   #4
Default Thanking the Wizard
Thanx Mr. Wizard. Your assistance has been very helpful.
Looking for DAC kit or prebuilt PCB for US$300 oon_the_kid Digital Line Level 4 17th July 2009 12:43 PM
ported box design question: is exceeding the Vas of the driver bad? BrianGT Multi-Way 13 15th May 2006 05:35 AM
Seas W18, sealed or ported design? graks Multi-Way 0 9th May 2005 07:24 AM
Ported Enclosure Design w/o Driver Theil-Small Parameters misterbobman Multi-Way 6 29th March 2005 02:06 PM
Woofer Towers, front-ported or rear-ported? Goldenboy Multi-Way 6 15th June 2004 06:44 PM
Page generated in 0.08035 seconds (77.01% PHP - 22.99% MySQL) with 10 queries
