Old 8th July 2009, 02:21 PM   #1
Default Speaker spec terminology, what do these mean?
Can anyone explain what these speaker spec terms mean?
Have looked on the net & books but to no avail.
Krm= in m Ohm
Erm=
Kxm= in m H
Exm=
Thanks for any help
Steve
Old 9th July 2009, 12:00 AM   #2
http://pagesperso-orange.fr/francis....ilIpedance.doc
‘today… there lives alongside the twentieth century the tenth or thirteenth. A hundred million people use electricity and still believe in the magic power of signs and exorcisms” Trotsky
Old 9th July 2009, 07:03 AM   #3
Thanks for that info Pete.
I have those specs for a speaker, but not Le, so I'm using the Le = Kxm x @ to the power of (Exm - 1) formula.
This part is confusing me;
>>where @ = 2 x pye x f; { f = frequency in Hz }
What frequency? Where do I get that figure?
Thanks for any help.
Old 9th July 2009, 09:59 AM   #4
bjorno is offline bjorno  Sweden
Send a message via MSN to bjorno
This part is confusing me; >>where @ = 2 x pye x f; { f = frequency in Hz } What frequency? Where do I get that figure?
Hi sparkless,
Maybe this could be of help? Picture 1(1) :
b
1(1)
Old 9th July 2009, 10:08 AM   #5
in those formulae, is x = multiplier? = *
kxm x w = K * M * w ???? (w= greek omega)
and Exm -1 = E * M^-1 = E/M??
otherwise, I am lost as well.
regards Andrew T.
Old 9th July 2009, 10:09 AM   #6
Pi = greek symbol for 3.14159 = Circumference / Diameter.
regards Andrew T.
Old 9th July 2009, 10:53 AM   #7
Hi Andrew,
Yes but not in Exm or Kxm where x indicates a reactive element.
I admit that using x as a multiplicative operator can confuse.
Here's a better picture:
b
1(1)
Old 9th July 2009, 09:44 PM   #8
Thanks Bjorno for that info.
>>Omega, f, are not constant but variable<<
Understood. What I am not sure about is , when the specification
Le is given for a particular woofer at what F is that figure based on?
I believe it is usually 1K, is that correct? (need this spec for Zobel)
Steve.
Old 9th July 2009, 11:19 PM   #9
Understood. What I am not sure about is , when the specification Le is given for a particular woofer at what F is that figure based on? I believe it is usually 1K, is that correct? (need this spec for Zobel)
Hi Steve,
Correct! The primary standard measurement point is at 1 k Hz.
b
Old 10th July 2009, 01:52 AM   #10
>>Correct! The primary standard measurement point is at 1 k Hz<<
thanks bjorno
So if I'm using a Zobel for a woofer that's to be crossed over at 2500Hz should f = 2500 to get the correct Le ?
C = Le/Rc2 Rc = 1.25 Re
dimentions of speaker box in speaker spec sheet? Dan2 Car Audio 2 6th February 2009 05:34 AM
Terminology Mat_89 Multi-Way 1 20th September 2006 08:54 PM
Jensen A-12 Speaker Spec... fishman Multi-Way 1 28th June 2004 07:19 AM
Speaker terminology AJ Bertelson Multi-Way 1 8th May 2004 02:43 AM
Terminology question SteveA Pass Labs 5 22nd December 2001 08:54 PM
Page generated in 0.10464 seconds (78.35% PHP - 21.65% MySQL) with 11 queries
