Title says it all.
I don't know of any stores that sell professional speaker grill cloth, but there must be some fabric that sounds/costs/looks just as good/better than the commercial stuff. The question is what? My ideas are window/door screen material, or silk, or something... cotton is probably the worst. Something synthetic like very thin polyester might be best. How do metal screens compare (considering sound only)? The cloth doesn't have to (but can be) be opaque, or rigid, or particularly sexy. Just needs to not sound like there is a grill cloth. |
#2 |
I've used "silk" that was meant for the surrounds of picture frames. I think it is actually rayon, most of it.
This can be found in most fabric stores in a wide varity of colors and textures. You want the lightest, most open you can get. It does not look like typical grill cloth, which is nice. It seems to have a little attenuation at the very top, so you have to live with it, or EQ it. But it's pretty transparent thru most of the audio range. Just an idea for a different, and perhaps prettier, way of doing it.
Take the Speaker Voltage Test! |
#3 |
If you want something that is very transparent both sonicly and visually you might consider trying black fiberglass screen door netting from your local Home Depot or equivalent.
You need to get it very taught because any little flaw will show, but you will get both a "finished" look to the speaker with virtually no "muffling" of the high frequencies and you will still be able to see the drivers (a personal preference) - gives it kind of a techno/industrial look. P.S. - consider offsetting the fabric 45 degrees to get a diamond pattern.
Soft Dome |
#4 |
frugal-phile(tm)
Go to a fabric store and ask for double knit... if you find the right stuff you can stretch it in both directions of the weave.
dave
community sites t-linespeakers.org, frugal-horn.com ........ commercial site planet10-HiFi p10-hifi forum here at diyA |
#5 |
you might want to edit that, Dave. Your typo resulted in a censor. LOL.
(another mod fixed it)
#6 |
Super-sized "shear" pantyhose.
How you obtain them.. well, that's up to you.
perspective is everything |
#7 |
In case it helps, here are a couple of links for cloth you can order on line...
Parts Express Meniscus Audio I have tried the Parts Express material and it works fine (no audible difference with grills on or off to my ears - with my old Advents). I ordered some of the stuff sold by Meniscus Audio to compare (my guess is they are the same polyester material, but time will tell). Bedsheets apparently work fine also. -Doug |
#8 | |
Soft Dome |
#9 |
I once found a brand of fishnet stockings called "Music Legs." (no kidding) Those should be perfect!
#10 | |
Soft Dome |
| Vandersteen 2C replace fabric grill cloth | skyhigh_ct | Multi-Way | 1 | 28th October 2008 12:19 PM |
| Attatching grill cloth | sbrunkow | Multi-Way | 8 | 25th May 2007 10:53 AM |
| Grill fabric ideas? | Javachip | Subwoofers | 2 | 11th January 2006 06:51 AM |
| Acoustical foam grill cloth? | woody | Multi-Way | 0 | 13th January 2003 12:10 PM |
| grill cloth in port | zach | Multi-Way | 5 | 27th October 2001 08:56 PM |
| Page generated in 0.10699 seconds (80.22% PHP - 19.78% MySQL) with 10 queries |
