Hello everyone ,
I bought HDS tweeter 1 year ago but it was never installed. Now I plan to use it in an application where the HP crossover needs to be around 2000Hz. What is the lowest healthy crossover point you can have with the HDS-tweeter, provided only 12dB (electrical) filter ? http://www.tymphany.com/datasheet/printview.php?id=170 Any comment much appreciated P.S, above link to datasheet is old one. - Now I could actually not find the HDS datasheet on Tympany's HP? (... strange...) LageB |
#2 |
You can test it in that (2k/12dB) xover range with no problem (Fs=700Hz for the HDS tweeter).
#3 |
2kHz for this tweeter is just fine, I use mine down to 1.5kHz.
The Peerless 810921 is now the Scan-Speak D2608/913000, see here at the bottom of the page. Also, measurements here.
The power of Science compels you! |
#4 |
Thanks Inductor & DcebeL
To DcebeL: Is your 1.5KHz xo-filter also only 2:nd order 12dB?? If so, the HDS tweeter must be indeed flexible - but, I guess you are careful not to crank up the volume too much then.. or..? LageB P.S Thanks for the info of name & brand change to S-S (it was not so easy to find) - I wonder why Tymphany did that?, by the way? |
#5 |
My crossover is 4th order acoustic at 1.5kHz, somewhere around 2nd order electrical I'm sure, without looking up the transfer function. The tweeter holds up just fine here, I encourage you to look at the measurement page I linked to above, it is class leading performance.
Scan Speak split from Tymphany a while back and took a few drivers with them from the other brands...As far as I know all the distributors still list it as Peerless 810921.
#6 | |
Ohh, divorce Scan-Speak & Tymphany was totaly news to me while today I learned it was old news (since May?). I have been out of the loop a while it seems. As for "HDS Tweeter" "the old name" I tend/hope to agree with you i.e what I have read sofar about this element seems, like, almost as good as it gets regardless price LageB |
#7 |
I am also interested in the HDS tweeter for my next all Peerless project. I think it is very good for its price.
From the datasheet, the HDS tweeter is not as flat as something like the SS6600. I guess the on-axis peak at around 15kHz can be trimmed down, but this could leave a larger dip at around 7kHz. It is not really the easiest to work with. What do you do with this tweeter? |
#8 | |
I will be using the HDS tweeter together with Fostex fullrange element acting only as woofer, in a In-Wall application (or "in-bookshelf"). Attached picture below Planned XO at 2000Hz I am not concerned of 15KHz peak at all for 2 reasons. (1) I can hardly hear 15,000Hz when I do test tones (2) Due to in-wall I will listen off-axis ![]() LageB |
#9 | |
DIY waveguide testing
Dan N. |
#10 | |
as different from 3/4inch deep + 3/4inch round over etc. 45degree chamfer - where? 1/2inch deep - where?
regards Andrew T. |
| Performance of Peerless HDS tweeter vs well-known domes | 2100 | Multi-Way | 4 | 23rd September 2008 03:44 PM |
| WTB: Peerless HDS 810921 tweeter | luvdunhill | Swap Meet | 1 | 26th November 2007 04:36 PM |
| peerless 810921 Tweeter | oldbar | Multi-Way | 1 | 12th November 2006 09:21 AM |
| Peerless exclusive tweeter comment? | tktran | Multi-Way | 9 | 26th July 2004 03:18 PM |
| Peerless tweeter | Ilianh | Multi-Way | 4 | 11th November 2002 03:03 PM |
| Page generated in 0.12273 seconds (81.23% PHP - 18.77% MySQL) with 10 queries |
