Hi
I just "found" this woofer crossover - I have never seen it before, used like this It works like a charm At least with my speakers Tighter more articulated and rythmik bass, quite a lot actually Highly audible improvement on midrange as well, more articulated and defined, especially on voices Tweeter sounds softer Ofcourse its system dependent and must match the rest of the crossover chain Might be worth a try |
#2 |
http://www.diyaudioandvideo.com/Calc...tour/Help.aspx
as you've used it, the R is bypassing the small L somewhat, so it'll bring your mids forward, giving the results you got; 'more rythmik bass' though? - I need a filter like this on my fingers, to improve my guitar playing
‘today… there lives alongside the twentieth century the tenth or thirteenth. A hundred million people use electricity and still believe in the magic power of signs and exorcisms” Trotsky |
#3 | |
Im not sure its that simple Without the resistor, the two inductors would simply be in series, and act as one The resistor virtually seperates them, as would a paralel component The improved mids comes solely from better phase relations, and gives better "timing" Remember this curcuit is used on double 8" woofers solely, in a 3way The much better rythmik and bass articulation is related to improved phase only I can promise you that bass qulity changes considerably with even small crossover changes, as does distortion Phase issues can do pretty strange things, such as slow down a driver, or make it seem too fast, and out of timing Good phase relations results in fast timing simultaniously with exstremely relaxed and precise presentation Though I really hate using bypass resistor on mids series coil, as mostly done, I may have to try whether this simplified double inductor arrangement works on midrange driver too
#4 |
New woofer xo implemented in speaker
Seem possible with much simpler midrange xo as well Sounds better than ever, very smooth |
#5 |
Have a play with this:
http://www.wisc-online.com/objects/i...objID=ACE10304 one of the effects of the parallel resistor is indeed reducing the phase angle...
#6 |
Thanks Pete
Fun thing Could be useful |
#7 |
Revised and simpler schematic
This one really works |
| Woofer-midrang crossover null question | gainphile | Multi-Way | 8 | 7th June 2009 06:26 PM |
| passive woofer crossover. | gvr4ever | Full Range | 3 | 15th May 2009 01:02 AM |
| <AUS> B3S active crossover design - Value woofer suggestions? | TheSeekerr | Multi-Way | 0 | 25th August 2008 12:46 PM |
| What kind of crossover do I need for this Dayton 5 1/4 Aluminum Woofer | kehi | Multi-Way | 6 | 16th December 2003 07:36 PM |
| Questions about Crossover for the new woofer driver | S.C | Multi-Way | 10 | 21st November 2003 07:11 PM |
| Page generated in 0.09663 seconds (79.52% PHP - 20.48% MySQL) with 11 queries |
