#21 |
Dilletante, tinkerer and beggathoner supreme
Expanding foam sounds interesting,
I once filled a pair of speaker stands with dry sand but stabilized with thinned polyester resin, that also may be interesting
QUOTE" The more I know, the more I know, I know (insert maniacal laugh >here<) NOTHING" |
#22 |
One step forward and two steps back
Sand is used for its inertial ( near zero ) characteristic. Using a lower mass material just fills the space but does not guarantee acoustical energy absorption. |
#23 | |
OK, fair enough.
But this is quite interesting: Quote:
I always thought, for most of us (I mean, speaker builders), the cabinet (mostly wood) work is the difficult and time consuming portion. Just like the metal work of the cases to the amp builders -- how I hate drilling and filing the case for a pre amp! Oh well, maybe it's just me. As to the OB "issues", those circuit things are actually easy to deal with. And I can't think of anything significant you'd have to "pay" for OB speakers. OK, I'm done on OB and won't persuade you any further. Anyway, please do update here for your metal work, I'm looking forward to see it. One last thing, would you consider placing the side walls inside the frame? I just love to see the exposing skeleton
#24 | |
I'm not advocating them, just said that it sounded interesting. Urethane board has been used for example in constrained layer construction
#25 | |
Sand. sand is the way to go.
Take the Speaker Voltage Test! |
#26 |
Hi JoeM
What are your cabinet dimensions internal,you might be able to get RHS or SHS in the right size for the inner shell . In SHS you can get 300mmx300mmx6mm square box. Or use channel and weld together . http://www.moorabbinsteel.com.au/channel.php Cheers |
#27 |
56oval, thanks for the link but square is SO yesterday
![]() Moondog, I have some urethane left. Im thinking some thin polycarb sheet formed similar to these ovoid with say 30mm cavity and sandwich of the same for top and bottom in a bookshelf would be a worthwhile test. All of 2 hours? And light! When you say stabilized, you mean mixed in? Would this not have a negative effect regards deadening? CLS, You dont need to convince me on OB I WILL be doing it eventually It's the power handling and room placement issues that Im not really looking forward to. Also cost. If Im going to do it it's worth doing right, ie Orions.picowallspeaker, Have you any info/links on all things 'inertial characteristic's regarding sand or other materials? I do worry a little about how it settles out after years, Im tipping larger particles sink eventually? |
#28 |
This cut away shows the bottom cross section. The top would be the same. All put together with liquid nails. No fastners needed.
The large square hole in the front and the round holes in the top and bottom plates are to have a sheet metal cover rebated inside and out and filled with sand. I think any sheet metal about 0.5mm would follow the horses shoe mdf 'plug' just fine. I've shown brushed stainless on the outside and galvanized inside. |
#29 | ||
They were VERY dead and solid though. I have another pair of "Apollo" stands with a 75mm tube upright perhaps I should experiment again. Which urethane? the diisocyanate type? that can be hazardous so use plenty of positive ventilation. I still one 500ml can of pre-mix left myself Quote:
I experimented with mixing chopped strand fiberglass with foaming resin once, for an automotive application; the foaming action carries the glass fibre to the outside seemingly making the skin stronger and more rigid. Those experiments were done many years ago at "Bostik" using Freon 113 and isocyanate based foams so may not translate to modern materials, those were the days; we used to wash our hands in the stuff; decant it from stacked 200litre drums and carry it around in open buckets.
#30 |
Excerpts from "Lautsprechergehause-baubuch" by Hans Herber Klinger ,1977
insonorisation: ...peaks...dips...non-vibrating-stop-the-oscillations...brick construction (!!!)no possible-better using wood,internally braced with bitumen impregnated foils...Tereform,Teroson (worse). A good way of isolating a cabinet ,making it proof from oscillating and inert to acoustic waves ,is to build a sandwich structure.Using MDF panels,allow 3-4 cm (!!!)between them and fill with dry fine sand.It has to be dry,otherwise when everything is well closed it will expand causing bumps or even explode (sic.). The sandwich principle is good indeed ,particularly against vibratory oscillation and sound-proof.On the other side the issue is that even little boxes , from 40 to 60 liters ,will weight a lot and will be difficult to move. But acoustic quality is substantially better than other methods . The importance of being sound-proof for a loudspeaker cabinet and the ability of loudspeakers to produce an uncolored sound , has been acknowledged only lately these years .Unfortunately it is not well acquainted enough . the non satisfying behavior of many boxes is due mostly to this. absorption: use lot of mineral wool in your vented boxes !!!!!!!! |
| fabricated steel enclosure bad for driver performance? | mrkahn | Multi-Way | 10 | 11th April 2008 03:52 PM |
| F200A in spherical steel infinite baffle enclosure | sharpi31 | Full Range | 10 | 3rd September 2007 11:59 AM |
| W-Frame or H-Frame dipoles? performace issues? | JinMTVT | Subwoofers | 34 | 5th October 2006 04:44 PM |
| My sand filled curved side walls project in progress! | sqlkev | Multi-Way | 17 | 11th August 2006 05:27 AM |
| Using steel enclosure as negative desireable? | franjy | Parts | 0 | 2nd July 2005 04:35 PM |
