#31 | |
#32 |
Well, they are visible when you walk by, the way I have mine set up. I knew they were going to be, so I tried to make them as insignificant as possible when I built them, but in a perfect world I suppose they would be either invisible or absent. I think it is good to be able to take off the back easily, though, and I wouldn't want to have to remove the grill cloth, woofer and fill just to do that.
- Doug |
#33 | |
It looks a bit dated, since 99/100 modern commercial speakers do not have screws showing on the back. Think about it ... furniture does not have screws showing either. I'd have an access panel on the bottom if at all - I've done this before. Even sometimes put the input panel down there. However, it seems you need rear access to the horn in this design. Pete B. |
#34 | |
#35 | |
I have hated that forever with many speakers. |
#36 | |
You can get some nice decorative brass screws and washers like these: Decorative Washers - Rockler Woodworking Tools |
#37 |
I like black button or pan head allen or security screws, they look more decorative and are usually hardly noticed in black:
Parts-Express.com:*#8-32 x 1-1/4" Black Machine Screw Button Head Security Hex | security screws security hex security screws screw hardware driver Pete B. |
#38 |
Yes, when I run through the parts that I have on hand I will change the design to a screw hidden woofer. Thats why I reduced the prices since the new design will have a higher price. |
#39 |
They are black and if the back is painted black, as I do, the screws are not noticable at all. If the back is not painted black, then yes, the screws will be apparent - so don' do that.
#40 |
| Matt's Gedlee Summa Abbey Kit Build | pjpoes | Multi-Way | 509 | 17th August 2011 01:36 AM |
| F1 or F2...which should I build for an Abbey | audionut | Full Range | 3 | 28th June 2009 03:56 AM |
| Page generated in 0.11450 seconds (82.56% PHP - 17.44% MySQL) with 11 queries |
