Old 5th July 2009, 12:00 PM   #1
swin1 is offline swin1  Australia
swin1's Avatar
Default Another Peerless 830875 Execution
Thought I'd post my latest creation:
http://www.ozphotolink.com/is.php?i=...g=SNV33488.JPG
http://www.ozphotolink.com/is.php?i=...g=SNV33489.JPG
A bit of background - built these over the Christmas holidays after arriving back from the UK. The tweeter is a Seas 27TFFC and the Woofer is a Peerless HDS 830875. Crossover uses bennic caps, standard 18guage air core inductors and 10w resistors. Picked up the drivers from another diyAudio member (thank you Chris) as I saw the opportunity to build a straight forward 2-way with a 7" driver. This is something I've wanted to do for a while but have been living around the world and didn't have easy access to work area or tools!
I was inspired by the idea of a traditional bookshelf (stand mount) design with good power handling using drivers with a smooth and easy rolloff, such as Zaph's SR71. In fact this design uses the same dimensions for the enclosure as the SR71 (Madisound's MD14) enclosure, but you save a little bit on the Peerless driver.
Cosmetically I used Victorian ash veneered 18mm MDF on all sides except for standard 25mm MDF baffle. The sides were chamfered front and back of the box, then copper coated along the edge. This is a good way of seemless mounting of the cut sides woofer which tends to look quite strange I think on uniform coloured baffles. I believe there needs to be something for those sides to line up with, anyone care to describe this in architectural terms?
The crossover is very simple, a design that gives the best power handling for this driver combination (which was my basic request to Madisound.) I am happy to post the LEAP output here:
http://2008.swinbank.fastmail.net/ro...erless2way.pdf
I have been absolutely thrilled by the results. I listen to lots of different kinds of music and what impresses me the most are the smooth bass response, voicing, imaging and handling of complicated passages such as hard rock. Initially I used an 0.82mh inductor on the woofer as this was what was locally available, and after noticing a slightly harsh sound, filled the air core with iron and measured the coil to spec, which flattened the filter out nicely.
Hopefully this gives some more idea's for others to work with!
Peace.
Old 5th July 2009, 12:05 PM   #2
jerome69's Avatar
Very nice project
Cheers.
Old 5th July 2009, 12:08 PM   #3
Thebrain's Avatar
oh! they are a thing of beauty
you should really not put speakers on hollow plastic boxes.
it will really mess up the bass clarity
Old 6th July 2009, 02:34 AM   #4
swin1's Avatar
Ha ha, yeah I know it's a temporary solution while I rebuild the stands, they are taking a while as the base will be 40mm concrete!
I should remember to post pictures when everything is actually complete.
Amplifier is a modified AMI Jorgen from the 70's, gutted and replaced by LM1875T kit from chipamp.com with 120VA 18v toroid, dead silent!
Old 6th July 2009, 05:22 AM   #5
Thebrain's Avatar
he he nice!
Old 22nd March 2010, 05:53 AM   #6
critofur's Avatar
Send a message via AIM to critofur Send a message via MSN to critofur Send a message via Yahoo to critofur
Hey, could you post the pictures and .PDF again? The links have since died. I have the same drivers and may as well try it, since you like it so well
Critofur
http://www.ohmspeakers.com <- all the folks here are my friends
Old 22nd March 2010, 06:37 AM   #7
links not working
Old 23rd March 2010, 07:59 AM   #8
swin1's Avatar
hey guys, pm me your e-mails and I'll send you the details of the project with madisound LEAP crossover design.
Old 16th April 2010, 05:10 AM   #9
critofur's Avatar
Pictures as promised:
Critofur
Old 16th April 2010, 05:16 AM   #10
picowallspeaker's Avatar
Nice stands ! Does the amplifier need a resonant chamber , either ?
And those things seem huge !! I just can't imagine how big is a floor tile...
Another LM1875 Chipamp Execution swin1 Chip Amps 1 12th July 2009 07:23 AM
FS: Peerless 830875 and SEAS H881 cs Swap Meet 0 12th November 2008 12:07 PM
Peerless 830875 vs SEAS CA18RNX cs Multi-Way 0 5th March 2008 11:51 AM
Series x-over for peerless 830875 and vifa xt25........ Gavinator68 Multi-Way 4 12th July 2006 10:55 PM
Peerless 830875 Nomex????? Gavinator68 Multi-Way 2 8th November 2005 01:55 AM
Page generated in 0.10680 seconds (78.27% PHP - 21.73% MySQL) with 10 queries
