Problem with distortion with OB line array
Old 2nd July 2009, 08:47 PM   #1
kipman725 is offline kipman725  United Kingdom
kipman725's Avatar
Send a message via MSN to kipman725
Default Problem with distortion with OB line array
Hi, I quickly prototyped some open baffle line array speakers using cheap 8ohm 120Hz - 16Khz "full range" 88dB/W 7.5cm dia drivers. They are wired in parallel series strings to present an 8ohm load. The problem is that at anything above moderate spl they distort quite nastily. I would describe the distortion as asif hearing a very loud sound (so loud that the ear produces a distirtion). I would guess standing waves of some sort as that is what causes the distortion in the ear at very high sound levels. Just to clarify the speakers are not outputting anything near that level before the distortion kicks in.
Anyway as a solution I was thinking of increasing the width of the baffle and the distance between the top and the bottom of the speakers and the top and the bottom of the panel (increasing overall height). I think also reducing the legnth of the longer stiffening strip may also help. Anyway any advice is apriciated as I am very novice at all this.
I am planning to use a pair of the improved version of this speaker with a couple of subs so thought the 120Hz point would be low enough for the crossover (poor student not everything can be hi-fi), however they apear to be cutting off way before that with the narrow baffle. Putting a sheet of MDF against the baffle side apeared to fix that though therfore increasing baffle width should help that aswell.
Old 2nd July 2009, 08:55 PM   #2
kipman725's Avatar
here is a pic of the original plan (missing one driver ^ ^).
Old 2nd July 2009, 10:40 PM   #3
HiFiNutNut is offline HiFiNutNut  Australia
A 7.5cm dia driver is rather small and even if you have 8 of them it does not total up a large radiating area. Plus if the drivers are very cheap then I am not surprised that they distort at higher sound levels.
I would find out the driver details, such as frequency response, impedance, Xmax, break-up regions, etc, before rebuilding the baffles.
Bill
Old 2nd July 2009, 11:18 PM   #4
PeteMcK is offline PeteMcK
OB, those will be inefficient and you'll be driving them quite hard for even low sound levels;
What sort of filtering do you have on them? try a series cap to limit bass levels below 150-200Hz and see if that helps?
Impedance varies with frequency, use impedance plots of your drivers and make crossover calculations using the actual impedance of the driver at the crossover frequency
Old 2nd July 2009, 11:24 PM   #5
Cal Weldon is offline Cal Weldon  Canada
Speakerholic
Cal Weldon's Avatar
I am surprised they are distorting at moderate levels. Do a quick check of the DCR with your multimeter to make sure you're not overdriving the amp. Those should be able to go quite loud before you hear the speaker distortion. And perhaps do as Peter says with the high pass cap. Also triple check your wiring to make sure there's no phase cancellation.
planet10 needs your help:
Let's help Ruth and Dave
Old 2nd July 2009, 11:54 PM   #6
tinitus is offline tinitus  Europe
diyAudio Moderator R.I.P.
I dont know
The idea is that cheap drivers are ok, if theres enough of them
Only, that rather "simple" way of looking at it mostly relates to woofers
Maybe you could try crossing them at about 300hz
Anyway, if you have a rising response curve, and no BSC, it could easily sound like its distorted
Phase issues could cause distortion too
And all those voice coils may take more power than you imagine
sometimes we know very little, and sometimes we know too much
Old 2nd July 2009, 11:58 PM   #7
kipman725's Avatar
its more off a high frequancy distortion problem, I have tried cutting the bass out and there was very little improvment the dc resistance is fine. the drivers are connected like this:
top
1---<+
2
3--->-
1---<+
2
3--->-
1---<+
2
3--->-
bottom
so 3 parallel strings of series drivers. Unfortunatly don't have any more detialed specs. Pretty sure the amp isn't overdriven as the same output level is fine when pluged into my 8ohm monitors.
Old 3rd July 2009, 12:04 AM   #8
Have you tried one single driver on its own
If it distorts, you will probably just get nine times that
Old 3rd July 2009, 12:10 AM   #9
Andy G is offline Andy G  Australia
Andy G's Avatar
poly cone, tin dome.. there's gunna be one heck of a breakup mode somewhere.
Old 3rd July 2009, 12:28 AM   #10
kipman725's Avatar
hmm I shall build a box for a driver on its own and see what that does, it would be a shame to have wasted money on some totaly awfull speakers.
Problem with distortion with OB line arrayHide this!Advertise here!
how to combine Line array and transmission line together Jared Multi-Way 7 15th December 2012 02:20 PM
line array + transmission line ? zobsky Multi-Way 12 16th August 2006 05:18 PM
NSB line array thylantyr Multi-Way 4 28th May 2005 01:22 PM
Line array tweeter line - On left or right? dhenryp Multi-Way 4 10th March 2005 12:35 AM
t-line subs for a DIY line array tom1356 Multi-Way 17 28th December 2002 01:15 AM
Copyright ©1999-2017 diyAudio
