#71 |
Check the seal around the woofer. Make sure it is airtight
QUOTE" The more I know, the more I know, I know (insert maniacal laugh >here<) NOTHING" |
#72 | |
Bill. |
#73 |
Door sealing tape, foam filler rod, soft string, blue tack; be careful with blue tack it is almost as strong as silicon,
#74 | |
Door jam tape sounds good! Thanks Ted! |
#75 |
Banned
Bill,
The Peerless 832873 has an integral gasket; grey, about 5 mm wide and 1.5 mm thick (if it thhat one we are talking about). Frank |
| passive network Z interaction for FR with helper | freddi | Full Range | 1 | 28th February 2009 06:29 AM |
| designing RIAA circuit #2: optimal drive current for de-emphasis network | Onvinyl | Analogue Source | 3 | 14th November 2007 04:22 PM |
| Designing Passive preamp | B&W_arthur | Pass Labs | 20 | 22nd May 2007 05:21 PM |
| Very strange HP Passive network for TAD 4001 | TADonly | Multi-Way | 5 | 30th May 2005 01:47 AM |
| Phy-HP crossover network HELP!!!!! | mmolina | Multi-Way | 1 | 13th December 2004 03:51 AM |
| Page generated in 0.09243 seconds (78.43% PHP - 21.57% MySQL) with 11 queries |
