First post
First post
Old 29th June 2009, 02:09 PM   #1
stampy is offline stampy  United States
Default First post
Hey guys. First off Im a newb to home theater and this is my first adventure into putting together my first real home theater setup.
So I just got finished with the construction of my left and right front speakers for my surround sound setup for my home theater. here's what i got:
mtm design on the speakers
peerless sds 6.5" mids ( http://www.parts-express.com/pe/show...number=299-250)
lpg 26NAFM tweets ( http://www.madisound.com/catalog/pro...roducts_id=544 )
crosses at 4k 6db (i went simple it was my first crossover Ive built)
sitting in 1.3 cube ported towers 3"port tuned to 45hz
My receivers is a panasonic SA HE-75
I haven't got the center or the surrounds done yet, but any way I wanted to test them out and see what they sounded like so i popped in iron man on bluray into my ps3, ran it in surround mode (dolby prologic2) and i had to crank the receiver up to -10 to get the volume i want out of my home theater. I though maby its a Impedance issue and i wired it up wrong but no, dmm says 7.6ohms on each speaker. Any body have any thoughts on this or is it normal with a setup with no amps?
Old 29th June 2009, 04:41 PM   #2
planet10 is offline planet10  Canada
frugal-phile(tm)
planet10's Avatar
First post
Default Re: First post
You've hooked them up as main left & right? Centre set to phantom (virtual/none)? By volumr to -10 do you mean 10 o'clock?
Where the volume ends up id usually more about gain structure.
dave
community sites t-linespeakers.org, frugal-horn.com, frugal-phile.com ........ commercial site planet10-HiFi
p10-hifi forum here at diyA
Old 29th June 2009, 08:22 PM   #3
Moondog55 is offline Moondog55  Australia
Moondog55's Avatar
For a cheap receiver running volume at -10 sounds about right to me.
I have to run my pioneer at -10 to get 105dB peaks.
My speakers are Cheap Sansui that use a very similar little woofer, have you set the sound to Front/large??
I'm not familiar with your set-up but if you are not using a LFE sub-woofer then what you have may be all you can get, have you access to a cheap sub for testing purposes
QUOTE" The more I know, the more I know, I know (insert maniacal laugh >here<) NOTHING"
First postHide this!Advertise here!
Not being able to post replies on any post on Parts &amp; Supplies Mayank Forum Problems 0 8th June 2007 02:38 PM
