Old 28th June 2009, 11:49 PM   #1
Pooley is offline Pooley  United Kingdom
Default Help with Beyma design
I'm still fairly new to this game and am looking for a bit of advice.
These plans tick the boxes as the cabs are compact and loud, however I would like to use them for home listening (with a single sub) when not out on event use. Will only using a small fraction of their power handling sacrifice sound quality? This would probably be the nail in the coffin and I'll look to a lower power design.
If this makes no difference to the audio then I'm going to get my hands on a DCX 2496 and play with different crossover types (working out beforehand which ones I can make with available components) as I'm unhappy with both the crossover having a lower power than the woofer (600W and 700W) and the slope\cutoff. What sort of power components will I need? I know nothing about power handling of inductors and I'll keep the voltage across the capacitors in check. For attenuating resistors what power is needed? Looking at commercial 600W jobs with supplied attenuation there is now way that the resistors can handle 600W, so what is the required percentage of this power for a xover around 1Khz?
Thanks for any responses, I've come a bit unstuck here. Can't seem to find much info on high power passive xovers (I only want to use one amp).
Tom
Old 29th June 2009, 04:56 AM   #2
http://www.falcon-acoustics.co.uk/pd...%20Upgrade.pdf
http://www.tomshardware.com/forum/49...ower-crossover
‘today… there lives alongside the twentieth century the tenth or thirteenth. A hundred million people use electricity and still believe in the magic power of signs and exorcisms” Trotsky
Old 29th June 2009, 09:10 AM   #3
Thanks mate, solved all my crossover questions in one fell swoop!
Is running a 700w driver at 100w going to degrade the sound quality significantly?
Tom
Old 29th June 2009, 10:25 PM   #4
I would think that there would be lower distortion at low levels
(actually, at home listening levels you likely to be using only ~ 1 watt)
PS, for reliability's sake, you should seriously consider going active & using 2 amps, you don't want your system to kark it in the middle of a gig...
Old 29th June 2009, 10:56 PM   #5
I like to do my critical listening at loud volumes
I do seem to be swinging a little towards going active, I'll wait and see the complexity/number of components I'll need to do both sides. It may turn out that an extra amp may be worth the cost/time difference
Thanks again
2 x Beyma 8bx NED 209 Swap Meet 5 9th February 2011 10:12 PM
-Beyma TPL 150 AMT flshzug Planars & Exotics 1 23rd June 2008 11:45 PM
Beyma 8BX sumacSK Full Range 37 17th April 2008 09:08 AM
Beyma MI100 kartsmart Multi-Way 1 17th February 2006 11:48 AM
beyma MC-115 Sony Multi-Way 4 11th January 2005 08:47 AM
Page generated in 0.10361 seconds (69.27% PHP - 30.73% MySQL) with 10 queries
