My first measurements Justmls - Page 2 - diyAudio
Old 27th June 2009, 08:15 AM   #11
Shaun is offline Shaun  South Africa
Shaun's Avatar
Originally posted by djarchow
As long as you place your reference probe after the capacitor, the measurement will be the same as without it.
Right. The problem I have seen, however, is further degradation of S/N towards the lower end due to the roll-off introduced by the cap. This may not be of that much significance. For instance, here widi has captured the most significant part of the tweeter's FR, and the low end can be tailed off. Agreed that with or without the cap nothing will change above 500Hz. The point of my addressing the low end data is that this is his first measurement, and that strange curve is bound to confuse any first-timer.
Shaun Onverwacht
|||||||||| DON'T PANIC ||||||||||
Old 27th June 2009, 11:59 AM   #12
widi is offline widi  Spain
widi's Avatar
Well friends, I used another amp, and again I made the measurements, the capacitor is placed on the negative tweeter.
Think that these new measurements.
Here: http://img.villagephotos.com/p/2009-6/1342104/2095188
Old 27th June 2009, 12:22 PM   #13
Shaun's Avatar
It is a bit better; you'll still have to do the tailing off, though. It will be better for your low frequency measurements.
Did you use this setup?
Shaun Onverwacht
Old 27th June 2009, 01:57 PM   #14
widi's Avatar
No, but I will put the capacitor, the output sound card, as you indicated in your schedule, and I will try.
This is what I post.
Old 27th June 2009, 03:10 PM   #15
Shaun's Avatar
If you want to use the series capacitor you must ensure that the reference point is on the tweeter side of the cap, as I have drawn. I have put the capacitor inside my jig with a bypass switch connected across it.
Shaun Onverwacht
Old 27th June 2009, 06:31 PM   #16
widi's Avatar
I put the capacitor, the output of the sound card.
As the measurements were good, I have adjusted the latency of the sound card in 2048, and the mic preamp to 256.
Here's the results:
http://img.villagephotos.com/p/2009-6/1342104/2095227
Old 27th June 2009, 06:47 PM   #17
Shaun's Avatar
The first photo looks much better. What is the difference between this and the second photo?
Shaun Onverwacht
Old 27th June 2009, 07:00 PM   #18
widi's Avatar
The first picture, the measurement distance is 70 centimeters, and the second at 8 centimeters from the tweeter.
Now you are good measurements?.
Old 27th June 2009, 07:04 PM   #19
widi's Avatar
Almost I forget, the sample rate is 48,000 instead of 44,100
Old 29th June 2009, 07:10 PM   #20
widi's Avatar
Shaun,Now you are good measurements?
Wallin II jig with JustMLS? Mos Fetish Multi-Way 2 9th December 2008 05:53 AM
Radio Shack SPL Meter and justMLS - I'm getting odd measurements... fjhuerta Multi-Way 19 2nd January 2008 02:39 AM
Looking for some help with JustMLS JonW Multi-Way 7 16th April 2007 09:03 PM
JustMLS impedance anomaly Mos Fetish Multi-Way 0 6th March 2007 01:00 AM
JustMLS problem a007udio Multi-Way 4 18th July 2005 08:49 PM
Copyright ©1999-2017 diyAudio
