Old 25th June 2009, 06:21 AM   #1
thadman is offline thadman  United States
Default Sources of distortion in ribbon loudspeakers
What are the sources of distortion in ribbon loudspeakers, whether they be significant or insignificant. Are these questions / statements accurate? If they are incorrect or incomplete, I would much appreciate some feedback.
Longitudinal waves are the source of translation (displacement) within the system.
Are transverse waves the source of distortion in the ribbon element itself? If so, are there any other mechanisms within the ribbon element that cause distortion?
As far as I understand, the inductance of a ribbon is very low, thus EMF will not be a significant source of distortion, removing the need for shorting rings that are very popular in dynamic cone drivers.
The uniformity of the magnetic field is likely to be a primary source of distortion. Non-linear motor force should be the same mechanism that causes distortion in subwoofer drivers.
The linearity of the spring force is likely to be a primary source of distortion (air-spring, mechanical reactive force). Is there a way to calculate the linearity of the mechanical reactive force?
The distance between the edge of the ribbon and the magnet allows air to pass. I believe the circumstances may be analogous to hydraulics (damping). I'm not sure what distortion mechanisms would arise because of this.
"It is a profound and necessary truth that the deep things in science are not found because they are useful; they are found because it was possible to find them."
Old 1st July 2009, 06:38 PM   #2
This topic was addressed before I believe.
Ribbon Tweeter Distortion
Mechanisms of distortion in ribbon loudspeakers thadman Planars & Exotics 23 27th July 2009 04:14 PM
Ribbon distortion jirka Multi-Way 4 2nd October 2006 08:22 AM
Ribbon Tweeter Distortion angsuman Multi-Way 50 7th May 2006 03:08 PM
Ribbon Loudspeakers, Theory and Construction by J.V.Verhagen, Ph.D wuffer Planars & Exotics 1 21st January 2006 10:51 PM
LM3886 Distortion Sources scott_jcp Chip Amps 1 6th April 2005 05:09 AM
Page generated in 0.07853 seconds (61.47% PHP - 38.53% MySQL) with 10 queries
