Fixing some speakers with a pair of blown tweeters, and finding a replacement isn't easy! Speakers are TDL RTL3s, as seen here:
http://www.tdl-loudspeakers.co.uk/rtl3.htm Tweeters appear to be a rebadged Vifa D20TD-05-06 which is a 20mm dome with 94mm face plate 6 ohms. It looks the same, even has the Vifa part number on the magnet! If anyone has a Vifa with a fitting face plate I'd be interested - D19 or similar. I found both those drivers online, but it turns out there is no stock I can find and they are discontinued. Just checking in case someone has them new or second hand and interested in selling.
AUDIO BLOG | Bass integration guide My work: www.redspade.com.au web design studio |
#2 |
I just Googled and found this at Madisound
http://www.madisound.com/catalog/PDF/DX19TD05-04.pdf 4R tho D19s are still in stock http://www.madisound.com/catalog/pro...oducts_id=8281 Actually looks smoother than the unit you wish to replace
QUOTE" The more I know, the more I know, I know (insert maniacal laugh >here<) NOTHING" |
| Rega R5 tweeters replacement. Help. | Fusion123 | Multi-Way | 2 | 31st October 2009 12:03 PM |
| Aurasound NTL25-354-4A Silk Line Source Tweeters | omarmipi | Swap Meet | 1 | 12th March 2009 04:58 PM |
| Acoustic Research LST replacement tweeters | Charles Wasserf | Multi-Way | 2 | 8th June 2008 02:28 AM |
| Source or replacement 2sa872 | Onvinyl | Parts | 3 | 7th October 2007 01:37 PM |
| B&W DM-220 Replacement Tweeters | racedirector | Multi-Way | 2 | 14th September 2005 07:58 AM |
| Page generated in 0.08016 seconds (71.72% PHP - 28.28% MySQL) with 10 queries |
