I'm using a seas MCA15RCY driver as a medium in a 3 way speaker with an OWI for the highs and an ATOHM D300P04 for bass. The cutoff frequencies are 300Hz and 2.5kHz. It is working fine until a level (volume) at witch the medium start to distort.
I am thinking about replacing the MCA15RCY with another driver like the Seas Excel W15CY-001. More linear excurtion capability, less harmonic distortion. Magnesium instead of paper. But it is a bass/medium driver. So can i expect this driver to be sonicaly better than the mca15rcy when used as a midrange ?
Do you know any other really good driver for that application ?
Thank you.
Guillaume.
Thank you.
Guillaume.
gbadaut said:I'm using a seas MCA15RCY driver as a medium in a 3 way speaker with an OWI for the highs and an ATOHM D300P04 for bass. The cutoff frequencies are 300Hz and 2.5kHz. It is working fine until a level (volume) at witch the medium start to distort.
Metal is not a good idea.
What about de C-Quenze 15 H by Audio Technology (15 H 52 06 13 SD)
Maybe there is also a problem with the (power W) components of the xover. Does the mid has any resistor by the way(?) (5/10W), caps with low voltage(63/100V), or inductors with a thin diameter (0,6<1mm) or bad quality cable connections since it should work good for ~100W.
Salut Guillaume !
Your crossover have a problem. No saturation with the MCA15 at high level in this project : http://www.diyaudio.com/forums/showthread.php?s=&threadid=140324&highlight=
I always play music loud
I would say again, after looking at the xover, check and post the power for M resistors as that should workout (half) the problem.
R2_M=4R7 should be ~/>20W (if not, use 4 power resistors)
R3_M=2R2 should be a good power resistor let's say ~/>10W
R1_M=2R0 should also be, a good power resistor ~/>10W (I'm not measuring or calculating)
Peak power is always a problem as it can be > 100W. If you have 50 volt RMS, can be 70 volts peak, you get ~400 watts across an 6 ohm load. That's why resistors need to be rechecked carefully... now apply the power you use to R2 rating (and to all components).
Jerome,
Do you mean the xover needs to be redesigned for different components (I think you mean this), or just (there is) some compensation for different saturations on compression, or both.
Guillaume,
If you get a xover and use different speakers, from what was intended, unless you have very close parameters, it needs to be redesigned and tested. I would disconnect the MID from the xover and connect it to the AMP and listen. That should be your image of a good performance having in mind that the woofer and tweeter are not connected. Post after you do some testing, don't use to much power (be reasonable here) the sound should come clean. ~89dB from 200Hz to 3K0Hz. (Do you have a small closed box with the mid?) The MID is your MAIN speaker here not an ordinary mid speaker. A lot of people in DIY fail to realize. Now after this testing if you don't like you can start looking for a different MAIN speaker.
Inductor said:Jerome,
Yes I mean The Guillaume crossover need to be redesign correctly.
The MCA15RCY can easily go down 200Hz but the electrical crossover should be 18dB.
The ATHOM D300 P04 , like a lot of 12", can works as high as 500Hz, .
The project, which I give the link, is an other project and I listen to it at high level and I never notice any compression on the MCA15 (500Hz LR2).
With a sealed box volume of 4.2 litres, giving a Q of 0.5. A second order electrical filter can provide a 4th order acoustic LR @ 300hz. The driver will fail from thermal overload way before you run out of excursion.
If you're getting some sort of excursion related problems, I suggest you change the xover.
There is no resistor in the direct path of the midrange. Condensators are SCR 400V and self are good quality air-core. I don't think there is anything wrong in this area.
The output of the amp never go higher than 30V peak. This gives a peak power in the 10 ohm resistor of sqrt(30*30/10)=9W max. The resistor is 10W and always stay cold.
If I disconnect the highs and the bass, I hear the distortion, when just playing the mid.
The crossover between the bass and the (mid+high) is done digitaly with the LspCad emulator. This allow me to draw the filter on my computer screen and to immediately ear the result.
I just tried an LR4 crossover and raised the frequency until the distortion disappeard. It seems to me that the sound begins to be really clean from about 400Hz and above. I 'm not sure that the bass driver is able to follow. Perhaps I'm wrong.
Will the W15LY be as good as the mca15rcy for this application ?
Guillaume.
Guillaume.
gbadaut said:There is no resistor in the direct path of the midrange. Condensators are SCR 400V and self are good quality air-core. I don't think there is anything wrong in this area.
It will be better if you publish the xover we are talking about...
The xo I use is the one described by MurphyBlaster for his CAOWI.
http://murphyblaster.com/content.php?f=CAOW1.html
And I'm just discovering that the driver he uses is the ca15rly (midbass) and not the mca15rcy (midrange) as me. I made a mistake. The two drivers looks very similar.
I saw that the mca15rcy is 2dB more sensitive than the ca15rly so I just tried to raise the tweeter level by 2dB. That makes a big difference, the balance is much more natural.
Conclusion : I will continue to work with that midrange and make a good crossover for it. I plan to cross it with an LR4 at 3kHz. Any advice is appreciated for the choice of the crossover.
Thank you for your help.
Guillaume.
Guillaume.
I have a suggestion
The driver
12" woofer (4 ohms) : ATHOM D300 P04
5" midrange (8 ohms) : MCA15RCY
3/4" soft dome tweeter ( 8 ohms ) : OWI
You can try 500Hz,3Khz ? As a starting point, you can use the crossover of the project Astasia, also see link above.
1. For the boomer (8 ohms to 4 ohms), Replace the 4.7mH (L_1B) by a 2.2mH, The capacitor value (C1_B) 56uF becomes 100uF.
2. For the tweeter (4 ohms to 8 ohms) change 14.7uF (C5_T) to 8.2uF , 6.8uF (C4_T) to 3.3uF, 0.12mH (L4_T) to 0.22mH
3. For tune tonal balance, adjust the level with the resistances in series (R2_M and R1_T?) with the midrange and the tweeter (3.3 ohms for both ?)
If you want further optimization, measurements needs.
Hope that helps
The driver
Hope that helps
guopinglove said:Look at the schematics, it make your MCA15RCY midrange work as a woofer! So the crossover is designed for 2 way system.
So what you have to do is put four more components. two 33uf caps and 4.7mf coils.
He said he is doing the bandpass XO using the XO emulator in LspCad. Well I assume he is using a bandpass, if not then that would certainly cause the MCA15rcy to sound bad.
Dennis
Yes djarchow, exactly. The highpass filter is done with Lspcad.
With Lspcad I can emulate many crossovers, ear them, compare them, without having to build them for real. The CSD measurement of the mca15rcy on the Astasia project will be helpfull for the choice of the crossover frequency.
gbadaut said:Yes djarchow, exactly. The highpass filter is done with Lspcad.
I used the mca15 in three way center channel speaker with the WM XO using second order electrical and acoustic slopes at 450 Hz. I tried crossing it lower with 2nd order slopes and didn't like the sound at higher volume levels.
Are you using actual measurements of your mca15s in your cabinets in LspCad?
I emulate my XO's in SoundEasy (like you did in LspCad) then measure the emulated results with my other PC just to verify that my driver measurements and simulation are correct.
Dennis
- MCA15RCY replacement
