#71 | |
#72 | ||
#73 |
Brandon,
- ( Big ) Thanks ! for your efforts on measuring ( & posting the results ) for some of the more commonly used drivers talked up on the various sites . - As long as you continue to post nearfield measurements , as well as distortion measurements I'll get useful data . - Here's a pic ( actually a collage made using your data ) of the GPA 414 . This was "assembled" using "Paint" & "PowerPoint" . - This is the size of pic I like to view using a 40 - 50 db vertical scale. It does offer better resolution . ![]() >< cheers ![]() ps; I don't find your "gated/MLS" results very worthwhile since it is obvious to my eyes that they have a lot of smoothing below 1K ( regardless of the formulas ) . |
#74 | |
#75 |
#76 |
Any updates for the 15" testing?
#77 |
Thanks for all your work.
I'd like to try Klippel's Xmax determination method, and I was wondering how you measured cone displacement?
double complete rainbow all the way!! |
#78 |
The below occurred OT in a thread at AVS; I thought I'd include it here for those interested.
************************************************** ****** Me: So you tested the QSC w/the foam and found it to be better? What about the XT1086? augerpro: You know I did the comparison on your XT1086 with foam and haven't really looked at the data yet as I've been so busy. I was going to post some of it and couldn't find some measurements so I think I may have forgot to save some of the data. I probably won't have time to re-measure either. BUT I did do a quick comparison while I was doing tha actual measurements and with foam it was smoother and flatter. I didn't compare IR or CSD but I do remember thinking the improvement was very significant for frequency response. I expect that the IR and CSD would show an improvement also. The improvement for the QSC wasn't quite as pronounced. I'm hesitant to make much more of a judgement on the comapison until I get a chance to look more closely at the data. But I can say you should definitly try the 1086 with the foam. I should have it in the mail back to you soon. penngray: Yeah but how did it sound? Augerpro: Didn't get a chance to do that either Me: "BUT I did do a quick comparison while I was doing tha actual measurements and with foam it was smoother and flatter. " Great! So if you didn't listen do you mean you saw the plots in real time while measuring? By smoother do you mean the whole response in general and/or the top octave suckout in particular? Augerpro: Yeah just after I had finished the last measurement I plotted the before and after responses. But I must not have saved the before impulse responses because later when I went to replot everything to make screenshots for the my website I could not find them. But what I remember was the response smoothed out above 8khz and the midband hump from 3khz to 8khz had flattened. Kind of strange really since the foam in the QSC just resulted in a 3 dB drop evenly above 2khz or so. But on the 1086 it was like 3dB for the midband and a bit less above and below, so the overall response was flattened. I'll try to look back through my data and see what I can find to post. ************************************************** ****
----------------------------------------- Noah |
| Testing TS with driver vertical | mashaffer | Multi-Way | 14 | 6th September 2008 07:30 PM |
| Testing Stepper Motor And Driver Board | artb | Parts | 0 | 1st July 2006 09:24 AM |
| Suspended driver ok for testing? | Mos Fetish | Multi-Way | 1 | 12th January 2004 11:50 PM |
