Driver testing results
Old 29th June 2009, 03:24 PM   #31
nickmckinney is offline nickmckinney  Barbados
diyAudio Member RIP
Originally posted by augerpro
Guess it just goes to show what modern FEM modeling can do accomplish.
All Lambda motors were hand drawn on a napkin, I have never modeled them actually. There were 2 parts to the design that interplayed with each other and canceled each other bad aspects I learned once I pushed them to their limits. One was the extreme extension of the steel pole as that height had not been done prior to that time, and the other was the extra thickness of the copper faraday sleeve/ring. By taking the pole piece out of the motor so far it lowered the B loss of the copper sleeve in the gap. A win win I learned especially once the voice coil and top plate were made taller to match.
Old 29th June 2009, 03:26 PM   #32
diyAudio Member RIP
Originally posted by ScottG
He also needs to substantially increase the eff. of the driver - making more a of "mid" driver and less of a "bass" driver. (..or at least provide that as an option.)
Meeting those two requirements (alnico + eff.) and I think we would have a single driver winner.
All it takes is money.....................
It can be done BTW with a slight re-engineer of a couple things, but its an expensive big step to take as it requires some serious minimum orders for materials.
Old 29th June 2009, 03:37 PM   #33
badman is offline badman  United States
badman's Avatar
Aw, c'mon, just slap a bucking magnet on there and whalah, problem solved
"The dawn of Bose created the "Man Cave" and reduced testoterone levels worldwide by 18.5 per cent" Peteleoni
Old 29th June 2009, 03:41 PM   #34
augerpro is offline augerpro  United States
I was referring to the Eminence and FaitalPRO woofers actually. They have quite linear and low distortion motors, but apparently don't have any shorting rings. Nothing special is said about the polepiece geometry either, but obviously they've been optimized pretty well.
~Brandon
DriverVault Soma Sonus
Old 29th June 2009, 07:48 PM   #35
Lynn Olson is offline Lynn Olson  United States
Lynn Olson's Avatar
The TD12M looks really good, no question about it. There are some interesting aspects to Augerpro's testing, though ...
Look at the GPA/Altec 414 "multitone_500Hz_100dB" graphs and compare the region above 2 kHz to all the other drivers - both 12 and 15-inch sizes. Set aside the number (which is set by the loudest harmonics) and look at the high-order distortion spectra (above 2 kHz).
The Altec has surprisingly low high-order distortion in the frequency range where the ear is most sensitive to distortion. These HF artifacts are not affected by electrical low-pass filtering of the driver - the test stimulus has no content above 800 Hz, so everything above that is driver distortion + noise. Against expectation, it is better than the TD12M, and much better than the other 12" and 15" drivers.
414 Distortion
TD12M Distortion
It might be the underhung voice coil and/or the Alnico magnet which are responsible for the notably cleaner HF characteristic. There's your triode-distortion harmonic spectra right there. The other drivers have more "clutter" in the 2~5 kHz region, which reflects the presence of additional high-order IM distortion terms.
On the other hand, the AESpeakers TD12M has a much better LF distortion characteristic, as shown by the "tone_150Hz_100dB" graphic, which is most likely the result of the exceptionally good Le(x) of the TD12M. It walks away from all the other drivers below 300 Hz, and is really good above 300 Hz.
I'll be doing subjective listening of the 414/Alnico, TD12M, and the 18Sound 12NDA520, with a primary focus on naturalness of the midrange with solo voice and choral music. Although the nominal crossover is 800 Hz, I don't plan on slopes any steeper than 12 dB/octave, so the quality above 800 Hz remains important. This is the same philosophy as the Ariel - each driver has to be natural-sounding without high-slope filtering to reject breakup regions.
Other designers rely on digital and/or high-slope crossovers to get what they want, but that's not the sound I'm after.
Old 29th June 2009, 08:13 PM   #36
diyAudio Member RIP
I tried to view some of the others but couldn't.
Check the TD12M vs the TD15M distortion and see what the differences are. Any difference should be entirely cone related. I always found the TD15M had a better mid/upper response (at least to my ears)
Old 29th June 2009, 08:13 PM   #37
The Altec has surprisingly low high-order distortion in the frequency range where the ear is most sensitive to distortion. These HF artifacts are not affected by electrical low-pass filtering of the driver - the test stimulus has no content above 800 Hz, so everything above that is driver distortion + noise. Against expectation, it is better than the TD12M, an unexpected result.
I noticed that too last night. Very interesting. The GPA softparts are really exceptional in that response even in breakup is really smooth. I haven't seen any other drivers with a cone or surround that looks the GPA stuff. I wonder where they get them from? And the pole vents out through the dustcap. Weird.
~Brandon
Old 29th June 2009, 08:15 PM   #38
TD15X or TD15M? I haven't tested the TD15M yet, although I believe John should have one the way from a drop ship order by a forum member.
Why couldn't you view the others? Something I need to look at on my end?
~Brandon
Old 29th June 2009, 08:38 PM   #39
badman's Avatar
This seems to me to be a good idea. The short path to outside air rather than into the enclosure is a plus, and also, no tube is necessary with that design, which avoids a resonant member near the cone.
Old 29th June 2009, 10:53 PM   #40
diyAudio Member RIP
The pole vents through the dustcap as they use a solid piece of steel for the top center pole piece (on top of the Alnico) This was common back in the day, most other drivers like this used a fully screened dustcap. Its either this or no dustcap (like our TD drivers)
TD15M - also I guess thats the reason I didn't see it
Driver testing resultsHide this!Advertise here!
Testing TS with driver vertical mashaffer Multi-Way 14 6th September 2008 07:30 PM
Testing Stepper Motor And Driver Board artb Parts 0 1st July 2006 09:24 AM
Suspended driver ok for testing? Mos Fetish Multi-Way 1 12th January 2004 11:50 PM
