I have a pair of Fostex 103e's at 15 watts , two Coral horn tweeters at 20 watts as well as a pair of JVC 15 inch woofers that cross at 800 hz that I think max out at 100 watts.
I have a Sansui 550 amp, two Quad 303's biamped with a 33 pre-amp, a separate 33 pre-amp connected to a 100 watt Quad 405, and a mint Akai AA-5800 that has been kept like new and sounds tight and crystal if that makes any sense. (I use it for some Bose's 901 series ll/w matching equalizer; that sounds very nice at reasonable volume). I'm running a mix of speakers around the house right now but would like to use the Coral, Fostex, Jvc in a Tri-amped situation in a tight space that bleeds into a bigger area. I see using the Sansui 550 with two channels out to the Fostex/Coral at 16 watts and the Quad 405 for the JVC bass speaker. Any ideas how to passively crossover using three seperate amps? |
#2 |
something like this?
http://www.t-linespeakers.org/tech/f...ssiveHLxo.html
Impedance varies with frequency, use impedance plots of your drivers and make crossover calculations using the actual impedance of the driver at the crossover frequency |
| Crossovers | IMSTOOPID | Car Audio | 0 | 2nd December 2008 12:39 AM |
| crossovers | tonysherwin | Multi-Way | 3 | 18th May 2008 12:30 AM |
| crossovers | tonysherwin | Multi-Way | 1 | 16th May 2008 10:18 AM |
| WTB: B&W 801 crossovers | aarsoe | Swap Meet | 0 | 6th October 2004 03:47 PM |
| crossovers | grim | Multi-Way | 3 | 22nd February 2001 01:52 AM |
