ARTA tweeter measurement problems - diyAudio
Old 21st June 2009, 08:00 PM   #1
doug20 is offline doug20  United States
Default ARTA tweeter measurement problems
Im having a hard time figuring out why I can not get Arta to give me a smooth response with running both tweeters in a test using pink noise.
Here is the FR Plot...
It looks out of phase ( or something similar, Im no expert) but I have swaped wires and Im using a DCX so I have changed the phase on each tweeter, I have modified everything and nothing will change. I have no idea what Im doing wrong.
Here are the indidual tweeter measurements
Left tweeter
Right tweeter
The measurements are done center of my listening area in my HT room center point between the tweeters 8 feet back.
Im really stuck now as to why this is happening, I could have screwed something up but my DCX is identical for both drives, I have triple checked my wiring too.
Old 21st June 2009, 08:19 PM   #2
breez is offline breez  Finland
Looks like comb-filtering effect. Nulls at approximately 4 KHz apart means a time difference of 0.125 ms (180 degrees phase shift) or a multiple of that. In distance this is 4.3 cm or a multiple. Try to carefully measure the distance to the tweeters from the mic position.
Why do you need to measure with both tweeters running?
Old 21st June 2009, 08:31 PM   #3
Thanks, I will take that measurement.
Why? Im curious about my overall in room response and any Im curious to what Audyssey is EQing (before and after).
Originally I was just measuring individual drivers to setup my crossovers/EQ settings via my DCX.
Old 21st June 2009, 08:37 PM   #4
Mic is 88" (223.52cm) from the left speaker, 83" (210.82cm) from the right speaker, the Mic is 35" (88.9) high, my tweeter centers are 38" (96.52) high.
Old 21st June 2009, 08:40 PM   #5
IF this is true shouldn't I be able to tweek the time difference in my DCX to fix this. I have tried many, many values in the delay setting and I saw no change.
Or moving my speakers would work but again no change
Old 21st June 2009, 08:53 PM   #6
Update, thank you!!
I re-measured, set the exact distances and we have a better measurement no lobing.
THanks for the little lesson about lobing between speakers, I only thought of lobing with the CTC spacing on a single baffle.
Old 21st June 2009, 09:03 PM   #7
Bingo! 223.52 - 210.82 = 12.7 cm. Approximately 3 times 4.3 cm. Disregarding the height difference, won't change the distance difference much.
Moving speakers or electronic delay should change the pattern (different nulls or no nulls), but you really shouldn't use delay to 'fix' the interference. While listening your head will move and the distance to one ear from the speakers will continually change. This would happen with any speakers with or without delay!
I'm not familiar with Audyssey, but it should measure one speaker at a time.
Old 21st June 2009, 09:14 PM   #8
full system measurement mains/subs
Couple of dips to work on if I can fix them at all.
and someday I need to figure out how to set Arta scales properly.
That measurement above was 80dB on my RS SPL meter.
Old 22nd June 2009, 11:37 AM   #9
Henkjan is offline Henkjan  Netherlands
Henkjan's Avatar
if the dips are from the driver, you can (and should) fix them easily with the Behringer, but if they are in the low end and caused by room modes, you probably should do something in the room.. and remember to measure at different locations, and not optimise for 1 location
Old 22nd June 2009, 12:38 PM   #10
Thanks,
They are caused by room modes so Im not sure there is a fix for some of them, speaker placement is restricted a little bit so I will live with some of the dips.
I also agree to measure at different locations. My only goal with this exercise is to learn more about measuring speakers (Gated reponse, THD, Impulse), Measuring room decay and also learning more about Arta.
In the end Audyssey will do its thing (I even have the Pro version on order) so that I can tweak it too a specific curve I like.
Tweeter problems - how to identify rotebailer Multi-Way 1 9th May 2009 04:05 PM
Anyone with a working ARTA measurement box ? zobsky Multi-Way 0 2nd July 2007 06:48 PM
Tweeter problems porfi4ever Multi-Way 20 8th October 2006 01:26 AM
ARTA Measurement Software hongrn Multi-Way 1 2nd July 2006 07:46 AM
Problems with ribbon tweeter and ZEN V4 Selfmade Pass Labs 9 10th October 2002 10:51 PM
Copyright 1999-2017 diyAudio
