Well, I know it's broken
But what's the likely cause of this? Bad coil winding? I'm seeing about 40-50R on the coil at DC, and measuring about 10dB reduced output. Should I just replace it, or can this be serviced? |
#2 |
Did you check the wiring/solder that leads to the cone?
-Micha |
#3 |
Up to where they enter the cone, it seems okay. I do think it's possibly a wiring problem on the other side, but I hesitate to cut out the dust cap and whizzer to figure it out (I don't exactly know what I'm doing). The first time I measured, I got 38R, now I get 63R.
| Electrovoice SP12C data? | Duo | Full Range | 8 | 5th March 2010 08:31 PM |
| Output coil on power amp... | Skorpio | Solid State | 119 | 31st May 2007 02:21 AM |
| High efficiency Field coil 10" midranges, Australia | tech.knockout | Swap Meet | 3 | 12th April 2006 07:28 AM |
