Any reason a cross-over circuit has to be active (with op-amps and such) just because it's upstream of the amp? I have a wideband driver that doesn't need all that much protection from low frequencies. 1st order is fine. The amp I want to use is short on power and I would like NOT to throw any of it away on a passive downstream crossover. If I'm interested in a 1st order high-pass crossover, why not put a capacitor UPSTREAM of the amp? Am I missing something?
NV&H |
#2 |
frugal-phile(tm)
community sites t-linespeakers.org, frugal-horn.com ........ commercial site planet10-HiFi p10-hifi forum here at diyA |
#3 |
SWEET. My amp has a high input impedance, so this should work fine.
NV&H |
#4 |
Your source has to be very low impedance to drive the passive filter before the power amp.
I am doing exactly that, but my preamp (which drives the filter) is capable of driving 200R load. Also you need a buffer after the passive filter, unless you install the filter right next to the input stage of the power amp. I use a John Curl JFET follower as buffer after the filter, as my power amp has 10k input impedance. Patrick |
| 45 fans – expanded horizons upstream? | rick57 | Tubes / Valves | 49 | 29th December 2008 08:42 PM |
| Passive crossover into active crossover | hahfran | Multi-Way | 16 | 10th February 2008 06:16 PM |
| Passive Crossover for Passive Subwoofer? | Toast_Master | Subwoofers | 23 | 30th April 2006 12:14 AM |
| Passive crossover | Twisted | Parts | 0 | 19th January 2004 08:32 PM |
| About passive crossover | stefanobilliani | Pass Labs | 5 | 2nd August 2002 07:39 PM |
| Page generated in 0.07705 seconds (71.69% PHP - 28.31% MySQL) with 10 queries |
