Measured monopole and dipole room responses - Page 50 - diyAudio
Old 18th October 2012, 06:07 PM   #491
Banned
Originally Posted by Elias View Post
Like you suggested single mono bass behind the head.
Dipole? Monopole? Listening distance? EQ?
If you stop and think about it, and recalling that we are talking about near field so room effect is diminished, it will generate identical ear signals so the only change for perception is inside the head. If there would be reflections like in a natural sound field the bass will likely be externalised.
It also depends somehow on the signal as well. In some recordings there might be reverberation down to bass range which helps in this matter. I remember synthetic bass was the worse stuck inside the head all the time.
- Elias
We're talking about sound reproduction in acoustically small rooms not sound production - your own words.
Old 18th October 2012, 06:14 PM   #492
Rudolf is offline Rudolf  Germany
Rudolf's Avatar
Originally Posted by markus76 View Post
Don't know what specific paper of Griesinger you're talking about but his stereo bass "installation" creates such "fluctuations" just at one or two single (!) frequencies.
It might be "Envelopment and Small Room Acoustics". Look at bottom of page 9 and 10, where he mentions in-the-head localization.
www.dipolplus.de
Old 18th October 2012, 06:15 PM   #493
puppet is offline puppet  United States
This is the basic layout.
Old 18th October 2012, 06:19 PM   #494
Elias is offline Elias  Finland
Elias's Avatar
Puppet, If the listener is inside the small circle then this is not the same at all what Markus was suggesting.
Liberate yourself from the illusion of two speaker stereo triangle
Dipole Bass vs Monopole Bass Stereophonic Sound from a Single Loudspeaker 3 Speaker Linear Stereo Matrix Wavelets
Old 18th October 2012, 06:21 PM   #495
Elias's Avatar
Yes, could be that, or one of the several of his papers which also mentions about this. I believe it is in his website.
Old 18th October 2012, 06:23 PM   #496
Elias's Avatar
Dipole, about 0.5m. Behringer
Do you believe the mixer/master engineer intended the bass to be inside the head ?
Old 18th October 2012, 06:36 PM   #497
keyser is offline keyser  Netherlands
keyser's Avatar
Thanks David,
I recently moved to a place where sound transmission to the neighbors is much more important, so I actually have been reading in. However, as you already pointed out most information regarding sound isolation concerns speech frequencies, while bass frequencies are actually much more problematic.
What do you think about the multi-sub approach and sound-transmission to the neighbors? In comparison to a single sub, multiple subs in general radiate more sound power for a given level at the listening position, so you might say there will be more transmission. On the other hand the extra power is used to cancel modes.
Dutch & Dutch
Old 18th October 2012, 06:52 PM   #498
Banned
Single mono dipole? Orientation? What EQ settings did you apply?
Of course not and as I already said, I don't get in-head localization like you do. All I get is deep, clean, tight, fast, articulated, ultra-smooth bass - best signal modulation reproduction
Maybe you're running the sub too high? Or it produces too much noise/distortion.
Didn't you find the smoothness of the frequency response quite enjoyable?
Old 18th October 2012, 07:00 PM   #499
Yes ... then I misunderstood markus.
Old 18th October 2012, 07:02 PM   #500
Banned
Which part? I was always talking about the source being very close, like 2'.
Getting Dipole bass out of a monopole subwoofer Hara Subwoofers 19 3rd January 2016 10:00 PM
Omnipole, monopole, dipole and...nopole?? terry j Multi-Way 25 1st July 2007 03:28 AM
Dipole vs monopole, balls or not ... ? Jussi Multi-Way 11 4th May 2006 03:38 PM
DBX vs BSS vs 24/96 for Dipole/Monopole combo..... gavinson Multi-Way 0 29th November 2005 12:07 AM
Dipole speaker with monopole rear firing midbass? GuyPanico Multi-Way 4 12th November 2005 02:49 PM
Copyright 1999-2017 diyAudio
