Measured monopole and dipole room responses - Page 43 - diyAudio
Old 15th October 2012, 05:42 PM   #421
Rudolf is offline Rudolf  Germany
Rudolf's Avatar
Originally Posted by markus76 View Post
Perceptually this is a day and night difference.
Yeah, if you can't change the walls, keep things far off the walls
www.dipolplus.de
Old 15th October 2012, 05:50 PM   #422
Banned
Originally Posted by gedlee View Post
If you take your sound system serious then you need to take the room serious as well.
Exactly. But when you can't change the room then you need to find a different solution.
Old 15th October 2012, 05:56 PM   #423
mondogenerator's Avatar
i tend to agree with earl on most points. I very hard reflective room is bad news, mono or dipole, its a matter of degrees of awfulness WRT midrange. In my old concrete home monopoles had rollercoaster bass which was apparent when i stood in an adjoining room or in certain places in the room.
Like all of my OB experiments, very quick and rough trials, the dipole sounded very indistinct in the mids. Bass wasnt considered, i was naive.
However it solidified my belief that dipoles are better used in treated rooms, just as the monopoles. The same 5 minute experiment in my current home is less clear, using my ears only.
My unscientific conclusion is this. A concrete floor generally tightens bass, due to a lesser or different excitation of its structure, compared to a sprung floor. Carpeting helps in this case. The worst listening room ive had was a victorian brick walled room with a sprung floor. Resonant floor AND high levels of modal excitation. All very anecdotal and non scientific, but 'real' enough to realise that some treatment is almost always a prerequisite for decent sound.
Balancing the things I must do, with the things I'd like to do...This is a skill (or a luxury) amongst many that I do not possess.
Old 15th October 2012, 05:59 PM   #424
Wavebourn's Avatar
Send a message via Skype™ to Wavebourn
Originally Posted by lolo View Post
more subjectively, aren't dipoles meant to give an edge on "natural" LF reproduction? less energy storage + less group delay compared to ported subs, and even closed boxes?
Indeed. But people here try to attribute the difference to the room response only, and to the reproduction of lowest frequencies only.
The Devil is not so terrible as his math model is!
Old 15th October 2012, 06:15 PM   #425
john k...'s Avatar
Originally Posted by Rudolf View Post
Just for the sake of comparison:
Attachment 306659
What was the direction of the dipole and cardioid axis?
Was there any attempt to rotate dipole or cardioid?
Did it make a significant difference (to the better/worse)?
Rudolf
The dipole and cardioid axes were at about 10 degrees from the room front to back direction. This is how I set up my NaO II Ra's which are positioned for best sound over all.
I have tried different positions and rotated the sources in the past (when I designed the CRAW). It makes the most difference with the dipole. There is no doubt in my mind that, in my room, dipoles are the most sensitive to position and cardioids the least. That's not to say that the response doesn't go to hell in a hand basket at some positions for all sources. But no matter how you set them up, there can be very drastic changes by moving my listening chair forward or back a few feet. Frankly I find the seating position to be the most critical component. I think what I need is a power seat so i can shift the listening position with a button, like a power car seat.
John k.... Music and Design NaO dsp Dipole Loudspeakers.
Old 15th October 2012, 06:24 PM   #426
gedlee is offline gedlee  United States
gedlee's Avatar
I agree.
I also agree that the approach that you are using makes sense. But I really think that in the end we will find that any multisub situation with independent DSP control on each sub channel, when properly setup, will result in just about the same "as-good-as-it-gets" in almost any situation. I really believe that years from now we will all being doing this and that the specific implimentations and "brand" names for the EQ type or the sub type will simply go away. We will simply ask "How many subs do you have?" and maybe "Whose DSP are you using?" Everything else will just be superfluous.
Its not like I haven't looked at this problem before, I have, and in some detail. I just see it all converging on what I have found to be the best solution. Minor deviations thats all.
Where was the paradyme shift? DSP - without cheap DSP the "optimal" methods are just not feasible.
Old 15th October 2012, 08:02 PM   #427
lolo is offline lolo  France
lolo's Avatar
that's exactly what I am doing, being at this stage the only solution for me. treatment is on its way though!
Earl, no need to be condescending, and no need for Bose either. As a treated room does not show significant differences, it seems obvious that a "rough" room would make these differences stand out more, that was it. As said, the lesson here, at least for me, is that the treatment seems more important than the radiation type. I still believe that dipoles keep that edge on "naturalness", call me audiophile if you want, that's just how I see it..
Maybe Stig Erik could try an interesting combo.. Earl's multi sub/dsp method but on dipoles? At least for fun?
Old 15th October 2012, 08:08 PM   #428
StigErik's Avatar
That's what I am doing. I have four dipole subwoofer towers (line-arrays), and DSP of course. And a a lot of bass-traps.....
dipoles dipoles dipoles dipoles dipoles dipoles dipoles dipoles and dipoles
Old 15th October 2012, 08:28 PM   #429
gedlee's Avatar
That misses the point. A treated room does not show differences between source types because the type does not matter all that much. There would be huge differences from room to room however, with less differences for treated rooms than non-treated ones. The point remains that any discussion that leaves out the room is not worth having because the variance is more room dependent than source dependent.
"Bose" was clearly a joke implying that if you are not going to optimize the room then why bother to optimize the speakers.
Old 15th October 2012, 09:12 PM   #430
john k...'s Avatar
... The point remains that any discussion that leaves out the room is not worth having because the variance is more room dependent than source dependent.
Yes, yes, yes!!! The only factor at odds with this is the possibility of room pressurization.
Getting Dipole bass out of a monopole subwoofer Hara Subwoofers 19 3rd January 2016 11:00 PM
Omnipole, monopole, dipole and...nopole?? terry j Multi-Way 25 1st July 2007 04:28 AM
Dipole vs monopole, balls or not ... ? Jussi Multi-Way 11 4th May 2006 04:38 PM
DBX vs BSS vs 24/96 for Dipole/Monopole combo..... gavinson Multi-Way 0 29th November 2005 01:07 AM
Dipole speaker with monopole rear firing midbass? GuyPanico Multi-Way 4 12th November 2005 03:49 PM
Copyright 1999-2017 diyAudio
