Measured monopole and dipole room responses - Page 39 - diyAudio
Old 14th October 2012, 08:58 PM   #381
Elias is offline Elias  Finland
Elias's Avatar
John,
Would you provide us some more information to make useful conclusions.
Room size ?
Speaker position ?
Mic position ?
Wall (celing, floor) materials ?
Acoustic treatments ?
It strongly looks like you are not living in a stone house
- Elias
Liberate yourself from the illusion of two speaker stereo triangle
Dipole Bass vs Monopole Bass Stereophonic Sound from a Single Loudspeaker 3 Speaker Linear Stereo Matrix Wavelets
Old 14th October 2012, 09:22 PM   #382
puppet is offline puppet  United States
John ... my only gripe ... your choice of blue and violet. I can't tell which is which. Maybe a nice orange for either next time?
:P
Old 14th October 2012, 09:38 PM   #383
Originally Posted by gedlee View Post
I am sure people will see huge differences where I see little, but in these last few weeks before the election that's pretty common place.
Yes, with the peaks and dips in the frequency responses they're difficult to compare. I don't know what to make of it all. I couldn't see how one could draw useful conclusions from this, except that the monopole is much more efficient below 60 Hz.
Might it be interesting to add EQ based on a spatial average and then compare again?
Old 14th October 2012, 10:09 PM   #384
john k...'s Avatar
Originally Posted by Elias View Post
John,
Room size ?
Speaker position ?
Mic position ?
Wall (ceiling, floor) materials ?
- Elias
This is a dedicated listening room build in the basement of my home. The room is approximately 16' wide by 20' long. The ceiling height is nominally 7' 2" but is stepped by about 3' in one area and has an 8" drop down across the length about 3' wide (to cover AC duct work). There is a sub floor over the concrete which is fully carpeted. The back wall is studs build against the concrete basement wall. The side walls are 2x4 studs with sheet rock on both sides. These walls are not against the concrete basements wall as there are other areas to each side of the listening room. The front wall (behind the speakers is also 2x4 studs and there is an air space about 2' wide between this wall and the concrete basement wall. The ceiling is also sheet rock on the 8" floor joists above. All walls and ceiling is insulated with fiberglass. There is also an alcove along one side wall that extends to the back (listening end) and also leads to the staircase up. So the room has a "stubby L" shape.
There are medium weight drapes behind the speakers. Side walls and back wall have no acoustic treatment other that a scattering of pictured in frames. My listening chair and a TV on one side wall are the only furniture but there are several other speaker system stored in one corner and there is an equipment cabinet between the speaker positions.
The acoustic center of the woofer was 3' 3" from a side wall, 4'3" from the front wall. This is the nominal position of my speakers as well. The mic was 5' 8" from the back wall, 3' high and centered left to right, at the listening position. Over all, above 100 or 200 Hz, RT60 is about 300 to 350 msec, which is in line with BBC type rooms, which is what I prefer.
John k.... Music and Design NaO dsp Dipole Loudspeakers.
Old 14th October 2012, 10:11 PM   #385
john k...'s Avatar
:P
The violet trace is the middle one at low frequency. It acrually look more black than violet.
Old 14th October 2012, 11:15 PM   #386
john k...'s Avatar
Originally Posted by StigErik View Post
At what distance are those CSD taken?
About 10' or a little over 3M.
Old 14th October 2012, 11:25 PM   #387
Elias's Avatar
Although we don't have modulation analysis results from John's system so the comparison is not possible, based on CSD it looks like in a purpose built dedicated listening room the differences between sources seem to be moderate.
Now try the same in a small shoebox living room in a concrete condominium. A different story alltogether.
- Elias
Old 14th October 2012, 11:45 PM   #388
john k...'s Avatar
- Elias
I have to admit that I am still struggling to understand the difference between the wavelet analysis and the raised cosine burst response. For clarity let me strees that the CSD is not a typical CSD. It is the burst response plotted as a waterfall. The sonogram is the same data, just plotted differently.
Old 15th October 2012, 12:13 AM   #389
Elias's Avatar
If the 'wavelet' is formulated having a raised cosine envelope then there is no difference with this 'non typical CSD', except slight mathematical issues like no imaginary part in a tone 'burst'. There are also different methods to calculate envelope. Overall it may also depend on how strick sense we need to define a 'wavelet'.
Still, one would hope to derive some modulation related parameters out from the measurements as it would give more relation of perception of music signals.
- Elias
Old 15th October 2012, 05:59 AM   #390
Thanks John for posting the measurements.
Just wanted a few clarifications:
1) Were the three bass units equalised to have a similar bass extension.
2)What was the BW tested.
3)Was the same driver used in the three units...or is it the same cabinet that was interchangeable into a monopole/cardioid/dipole.
4)Since the measurements look very similar above 50 Hz, what was your subjective perception comparing the three. Even as per Dr. Geddes from 125 to 500 Hz, dipoles may have benefits over other units, perhaps due to directivity (if I understood him correctly).
Thanks again for your measurements.
Getting Dipole bass out of a monopole subwoofer Hara Subwoofers 19 3rd January 2016 11:00 PM
Omnipole, monopole, dipole and...nopole?? terry j Multi-Way 25 1st July 2007 04:28 AM
Dipole vs monopole, balls or not ... ? Jussi Multi-Way 11 4th May 2006 04:38 PM
DBX vs BSS vs 24/96 for Dipole/Monopole combo..... gavinson Multi-Way 0 29th November 2005 01:07 AM
Dipole speaker with monopole rear firing midbass? GuyPanico Multi-Way 4 12th November 2005 03:49 PM
Copyright 1999-2017 diyAudio
