Old 14th October 2012, 12:47 AM   #371
KSTR is offline KSTR  Germany
KSTR's Avatar
Originally Posted by KSTR View Post
I'll open a new thread for this, here it will get lost and it is slightly off-topic anyway.
Here we go : Low Frequency Sine-Burst Test Signals for Room and Loudspeaker Evaluation
Old 14th October 2012, 01:02 AM   #372
john k...'s Avatar
Originally Posted by Baseballbat View Post
Of course not, I didn't meant that.
In modal region, a null (pressure node) at the listener position is (can be) a peak (velocity node) at another position in the room. So if you reduce the level at a null at the measured position, you can reduce the level of the peak at the other position.
Yes, of course. That is why I said source-to-listener transfer function. And that is the problem with room eq. EQing a what appears to be a peak at one position may result in a deeper null at another.
John k.... Music and Design NaO Dipole Loudspeakers. "We have no right to assume that any physical laws exist, or if they have existed up to now, that will continue to exist in a similar manner in the future." Max Planck
Old 14th October 2012, 07:13 AM   #373
But if there's already a deep null, it is no problem if you set a notch on it, thus reducing energy of that mode. It can give you more uniform response all over the room (with, of course, deeper nulls, but reduced peaks).
The problem is to define what's a "deep" null. And to conclude from the null on the right parameters for the notch.
That's the difficulty when EQ'ing based on only one measurement at the listener position. I wrote a commercial software (will run in the subwoofers processor) that does exactly that: measure at one position, calculate the parameters for the PEQs. Only for peaks, not for the nulls, I disabled that feature because it was not possible to automate that. But from my experiments, you can get very good results if you place the mic on a corner of the room; and maybe have bad luck that at your listening position you suddenly have nearly no bass. But this is rare.
Old 14th October 2012, 11:29 AM   #374
Elias is offline Elias  Finland
Elias's Avatar
Originally Posted by john k... View Post
There is no need to actually "play and measure" the test signal.
There is definitely a need to do both: measurements and listening tests.
When one chooses to do the measurement using signals which can be listened it becomes possible to achieve 1-to-1 correlation with the measurement results and auditory perception. This is the whole purpose.
The perception is all the matters. If I wouldn't hear any difference, say between monopoles and dipoles, I propably wouldn't bother about all this.
- Elias
Home page
If our hearing would be accurate, we would be hearing two loudspeakers.
Old 14th October 2012, 02:41 PM   #375
Rudolf is online now Rudolf  Germany
Rudolf's Avatar
Well said. I am curious what degree of 1-to-1 correlation you can reach. Is it just "dipoles are more open" or can you relate individual visual details of your diagrams to details of your listening impression? Would you also be able to relate those details to things in the physical world?
Rudolf
www.dipolplus.de
Old 14th October 2012, 04:31 PM   #376
john k...'s Avatar
Ok. I have made some measurements for monopoles, dipole and cardioid. I willmake several posts.
This first figure shows the near field response of the front source of the monopole (blue), dipole (green) and cardioid (violet). The individual responses have been Eq'ed such that when the dipole and cardioid front and rear sources are summed in the far filed all three formats will have the same on axis response.
This next figure confirns that when the front and rear sources of the dipole and cardioid are summed in the far field the response matches themonpole.
The next three plots are the in room response of the three sources. Note the lables in the lower left corner of the plots. The front source of each format was at the same position. That is, all sources had the acoustic center at the same location.
Note that the dipole and cardioid are very similar and that the monopole shows some room pressurization.
Old 14th October 2012, 04:42 PM   #377
john k...'s Avatar
Next, here are burst respons eplots presented in sonogram and CSD form. Note that the plots are in cycles so a line of constant time is shown in the sonograms for aid in interpretation. Again. see the lower left corner of the plots for the label.
Monopole:
Dipole:
Cardioid:
CSDs:
Monopole:
Dipole:
Cardioid:
Make what you like of the results. IMO, the dipole and cardioid preform pretty similarly. But recall that the cardioid is 6dB more efficient and cabn play 6dB louder. I may add some EQ to extend the bass response flat to 30 Hz.
Old 14th October 2012, 04:55 PM   #378
Thanks John. Is this a room with rigid walls or a typical stud wall?
Markus
Old 14th October 2012, 07:15 PM   #379
gedlee is offline gedlee  United States
Thanks John - completely plausible results. Its good to see real data.
It's clear that there is some effect below the first mode and hence the "room pressurization" (its not a dominate effect, but it is clearly there.). It's really the only significant difference in the results that I see.
I am sure people will see huge differences where I see little, but in these last few weeks before the election that's pretty common place.
Old 14th October 2012, 07:25 PM   #380
StigErik's Avatar
At what distance are those CSD taken?
dipoles dipoles dipoles dipoles dipoles dipoles dipoles dipoles and dipoles
Omnipole, monopole, dipole and...nopole?? terry j Multi-Way 25 1st July 2007 03:28 AM
Getting Dipole bass out of a monopole subwoofer Hara Subwoofers 18 14th July 2006 12:55 AM
Dipole vs monopole, balls or not ... ? Jussi Multi-Way 11 4th May 2006 03:38 PM
DBX vs BSS vs 24/96 for Dipole/Monopole combo..... gavinson Multi-Way 0 29th November 2005 12:07 AM
Dipole speaker with monopole rear firing midbass? GuyPanico Multi-Way 4 12th November 2005 02:49 PM
Copyright ©1999-2013 diyAudio
