#251 |
Tastes differ. Some prefer to hear forest, or concert hall, in living room. Some prefer to hear living room, with birds or orchestra in it.
If I disappear suddenly, that means I finally created a time machine and pushed wrong button that brought me to Stalin's Russia. In any experiment any result is the result. Even if it is negative. |
#252 |
And some prefer to hear music the way that it was recorded - you know "Hi-Fi"!
#253 |
#254 | |
Markus |
#255 | |
#256 | ||
#257 |
Here's the FFT frequency responses of the same impulse responses as before.
In this metrics they both are bad, and they just suck in a slighty different way. Compare these FFT curves with the pics from post #212. Dipole: Monopole: Clearly, comparing only FFT responses to find the better performing solution is a dead end. - Elias
Home page If our hearing would be accurate, we would be hearing two loudspeakers. |
#258 |
Yes, but ... In the long run if we just avoid this issue then it's not even worth coming to DIY (or any other site). It's just the "same old, same old". You either fight the laudable fight or go away.
#259 | |
Further - that data is obviously bogus since they both have the same level of LF excitation and that is impossible. Last edited by gedlee; 8th October 2012 at 06:59 PM. |
#260 | |
You propably mean echoic ? I do have 3D room impulse response simulator which can generate impulse responses from monopole, dipole and cardiode in an arbitrary room. I made it with Octave, how else It is easy to simulate any source location and orientation. It has been a long time dream to do exhaustive simulations on these source types in a small room, but unfortunately time has allways found better use. One day, I hope and belive ! - Elias
| Omnipole, monopole, dipole and...nopole?? | terry j | Multi-Way | 25 | 1st July 2007 03:28 AM |
| Getting Dipole bass out of a monopole subwoofer | Hara | Subwoofers | 18 | 14th July 2006 12:55 AM |
| Dipole vs monopole, balls or not ... ? | Jussi | Multi-Way | 11 | 4th May 2006 03:38 PM |
| DBX vs BSS vs 24/96 for Dipole/Monopole combo..... | gavinson | Multi-Way | 0 | 29th November 2005 12:07 AM |
| Dipole speaker with monopole rear firing midbass? | GuyPanico | Multi-Way | 4 | 12th November 2005 02:49 PM |
