Measured monopole and dipole room responses - Page 25 - diyAudio
Old 7th October 2012, 10:00 PM   #241
Elias is offline Elias  Finland
Elias's Avatar
Originally Posted by markus76 View Post
"Subjective Preference of Modal Control Methods in Listening Rooms", J. Audio Eng. Soc., Vol. 60, No. 5, 2012 May
Interesting, but as I learn they didn't test dipoles. Damn. Research must go on.
Liberate yourself from the illusion of two speaker stereo triangle
Dipole Bass vs Monopole Bass Stereophonic Sound from a Single Loudspeaker 3 Speaker Linear Stereo Matrix Wavelets
Old 7th October 2012, 10:03 PM   #242
Elias's Avatar
Originally Posted by _Wim_ View Post
Hello Elias, would your program run in scilab (http://www.scilab.org/) also? Or does is use functions only supported by Octave
Hi, I didnt try Scilab. In theory both Octave and Scilab are Matlab compatible so I think there should be no big problems as I used only basic functions and nothing Octave specific comes to my mind.
If you are using Scilab, yes please, share with us how it goes if you run the script.
Old 8th October 2012, 12:38 AM   #243
Originally Posted by gedlee View Post
No, not really. You act as if you are the first person to consider this topic and sudenly you have found the answer that has alluded all others. No, this does not seem very likely to me.
This thread sounds like "I know that dipoles sound best, therefor that technique which supports this conclusion provides the correct metric." That's not science. I know of no data that supports the assumption.
Everybody has his own perception.
To me this thread sounds like "MANY find dipoles sound most natural. Let us find the science /metric to support this". Many theories in science started with an astute subjective observation made just by the sensory organs of humans...that was later supported by the physics and math. Newton "saw" an apple falling. We "hear" a dipole as the better sounding.
I would be very interested in the dipole vs cardioid comparison using Elias's methods by JohnK.
Old 8th October 2012, 05:00 AM   #244
_Wim_ is offline _Wim_  Belgium
Ok, I will give it a try and post back.
Old 8th October 2012, 12:47 PM   #245
gedlee is offline gedlee  United States
gedlee's Avatar
Agreed, as long as the researcher leaves open the possibility that his initial assumption/hypothesis is incorrect - i.e. maybe dipoles are not the best sounding LF source. I, for one, do not believe that they are. I don't believe that anything else is any better either. I believe that it all depends on how the room and subs are setup and that the source type is a distant second in importance.
Earl Geddes Gedlee Website
Old 8th October 2012, 01:16 PM   #246
Banned
The source type is just a tool to reach a certain goal. Unfortunately in consumer audio land the tool somehow became the goal.
Old 8th October 2012, 01:24 PM   #247
puppet is offline puppet  United States
In all fairness, it is hard to separate the two (goal/tool) in your statement markus. Since acoustic reproduction is taste driven, the goal determines the source type.
Old 8th October 2012, 01:26 PM   #248
Banned
Don't bite, don't bite, don't bite...
Old 8th October 2012, 01:36 PM   #249
OK ...
:P
Old 8th October 2012, 04:01 PM   #250
gedlee's Avatar
Yes, that's true. Things become problematic when the tool characteristics become the basis for supposedly generic metrics used to evaluate performance. The performance metrics have to come from subjective studies, like the one that you asked about - a very good start.
It's very hard sometimes.
If the bottom line is "What sounds good to me.", then what is this thread all about?
Getting Dipole bass out of a monopole subwoofer Hara Subwoofers 19 3rd January 2016 10:00 PM
Omnipole, monopole, dipole and...nopole?? terry j Multi-Way 25 1st July 2007 03:28 AM
Dipole vs monopole, balls or not ... ? Jussi Multi-Way 11 4th May 2006 03:38 PM
DBX vs BSS vs 24/96 for Dipole/Monopole combo..... gavinson Multi-Way 0 29th November 2005 12:07 AM
Dipole speaker with monopole rear firing midbass? GuyPanico Multi-Way 4 12th November 2005 02:49 PM
Copyright 1999-2017 diyAudio
