Measured monopole and dipole room responses
Old 14th July 2009, 11:57 AM   #41
Elias is offline Elias  Finland
Elias's Avatar
Hello,
Here comes more measurement results Again the purpose is to study the room response of speakers having different radiation patterns.
I did several measurements in four locations A, B, C and D in the room. See the pic for positions.
I measured the following speakers:
- Monopole bass. One 12" element in a 100 litres closed box.
- Dipole bass. Two 12" elements in a H frame.
- Monopole bass-midrange. One 6.5" element in a 12 litres closed box.
- Dipole bass-midrange. One 8" element in a small open baffle.
- Dipole line array. Eight 6.5" elements in a vertical narrow baffle having height of 1.5 m.
The measurement signal is the same as before. It is a 5 cycle sinusoidal burst having Hanning envelope. Burst frequencies are spaced at 1/12 octave.
- Elias
Liberate yourself from the illusion of two speaker stereo triangle
Dipole Bass vs Monopole Bass Stereophonic Sound from a Single Loudspeaker 3 Speaker Linear Stereo Matrix Wavelets
Old 14th July 2009, 12:13 PM   #42
Elias's Avatar
At first, let's examine the frequency range of 20Hz-100Hz.
Here's the monopole bass room response:
File Type: jpg monopolebass_a-b-c-d_spektrogram_20-100hz_da_resize_90.jpg (79.7 KB, 641 views)
Old 14th July 2009, 12:18 PM   #43
Elias's Avatar
And here's the dipole bass:
File Type: png h-dipolebass_a-b-c-d_spektrogram_20-100hz_da_resize.png (97.5 KB, 625 views)
Old 14th July 2009, 12:29 PM   #44
Elias's Avatar
Here's the monopole bass envelope magnitude and envelope delay frequency responses.
The envelope magnitude is the maximum value of the envelope at the given frequency. The envelope delay is the delay the maximum value of the envelope occurs from the time point it should occur ideally. Zero envelope delay means envelope maximum is in the correct position with no additional delay.
Old 14th July 2009, 12:30 PM   #45
Elias's Avatar
And here's the dipole bass envelope magnitude and envelope delay frequency responses:
Old 14th July 2009, 09:20 PM   #46
cuibono is offline cuibono  United States
cuibono's Avatar
Nice work, thanks for sharing!
Old 14th July 2009, 10:08 PM   #47
gainphile is offline gainphile  Australia
gainphile's Avatar
Thank you !
Would you care to provide some explanations, which area to look for and if there's any conclusions ?
Cheers!
http://gainphile.blogspot.com
Old 15th July 2009, 12:56 AM   #48
john k... is offline john k...  United States
john k...'s Avatar
Are the dip[oles and monopoles equaized to have the same anechoic, on axis response?
John k.... Music and Design NaO dsp Dipole Loudspeakers.
Old 15th July 2009, 09:48 AM   #49
Elias's Avatar
Hello,
Yes, I'm planning to draw some conclusions some of which I think can be quite interesting, but first I have more data to present
The Envelope Mag frequency response curves ARE NOT equalised to be the same for different speakers. For the dipoles I use some slight 6dB/oct dipole correction only, but that is mainly to increase the dynamic range of the measurement.
The spectrograms ARE equalised mathematically so that at each frequency the maximum value of the envelope is referenced to 0 dB. That can be seen in the spectrogram pics where the max value has allways the same colour. I think this equalisation gives better view of the room temporal response since one can directly compare different speakers at different frequencies one to one.
- Elias
Old 15th July 2009, 09:51 AM   #50
Elias's Avatar
To continue, let's move higher in frequency and look at the range of 20Hz to 2kHz.
First here's the monopole bass-midrange room response at different locations A, B, C and D:
File Type: jpg monopolemid_a-b-c-d_spektrogram_20-2khz_da_resize_80.jpg (83.8 KB, 422 views)
Measured monopole and dipole room responsesHide this!Advertise here!
Getting Dipole bass out of a monopole subwoofer Hara Subwoofers 19 3rd January 2016 11:00 PM
Omnipole, monopole, dipole and...nopole?? terry j Multi-Way 25 1st July 2007 04:28 AM
Dipole vs monopole, balls or not ... ? Jussi Multi-Way 11 4th May 2006 04:38 PM
DBX vs BSS vs 24/96 for Dipole/Monopole combo..... gavinson Multi-Way 0 29th November 2005 01:07 AM
Dipole speaker with monopole rear firing midbass? GuyPanico Multi-Way 4 12th November 2005 03:49 PM
Copyright ©1999-2017 diyAudio
