Measured monopole and dipole room responses
Old 15th October 2012, 05:56 AM   #391
seanny is offline seanny  United States
Hi John,
would you high pass the monopole to be comparable to the other 2 then run the test for it again?
Old 15th October 2012, 07:20 AM   #392
markus76 is offline markus76  Germany
Banned
Originally Posted by john k... View Post
This is a dedicated listening room build in the basement of my home.
Such a room probably doesn't generate the data we're looking for. The typical North American stud wall construction works as a good low frequency absorber. In Europe, one is more likely to find rooms with rigid walls and severe modal ringing.
Old 15th October 2012, 09:09 AM   #393
mondogenerator is offline mondogenerator  England
mondogenerator's Avatar
in the UK, most pre-1960s homes are brick, post 1960 are breeze block, and for at least 20years they became stud wall. In my 5yr old home they are twin layer plasterboard with green glue, and cement loaded MDF floorboards.
Generally.
Balancing the things I must do, with the things I'd like to do...This is a skill (or a luxury) amongst many that I do not possess.
Old 15th October 2012, 10:10 AM   #394
Banned
I once have seen data from a converted attic which had unbelieveable low modal ringing. The neighbors probably could hear the bass very well too
In any case the solution has to be tailored to the room. It's not as simple as "multiple subs is best" or "dipoles is best".
Old 15th October 2012, 10:24 AM   #395
john k... is offline john k...  United States
john k...'s Avatar
Guys, you are not paying attention. In my first post I showed that all three sources have the same anechoic far field response. Differences in the in room results are due only to how the different sources behave in that room. Everything is fixed but source type.
See the top two plots in post 376
John k.... Music and Design NaO dsp Dipole Loudspeakers.
Old 15th October 2012, 10:34 AM   #396
Banned
Yes sure but the damping of your room probably dominates the results too much. We should look at the behavior in a room with rigid walls. This would make any differences caused by source type more obvious.
Old 15th October 2012, 10:35 AM   #397
Elias is offline Elias  Finland
Elias's Avatar
John,
What are the perceptual differences between the three source types in your room in the same configurations as the measurements were taken ?
Have you tried to listen modulated tone bursts ?
- Elias
Liberate yourself from the illusion of two speaker stereo triangle
Dipole Bass vs Monopole Bass Stereophonic Sound from a Single Loudspeaker 3 Speaker Linear Stereo Matrix Wavelets
Old 15th October 2012, 10:46 AM   #398
Banned
Originally Posted by Elias View Post
John,
- Elias
Look at the burst decay. The only perceptual difference is probably caused by magnitude differences.
Old 15th October 2012, 11:01 AM   #399
john k...'s Avatar
I'll post the impulse responses. I don't think you would say it's all that damped. My room is probably more rigid than a typical listen room here in the USA, particularly for the axial modes in the front to back direction where there are concrete walls directly behind, or within a couple of feet of the studded walls. What to you guys live in, concrete boxes?
John,
- Elias
I don't listen to test signals. I have no idea what they are supposed to sound like. As far as music goes, you may recall that the original NaO II had a woofer system which could be mechanically and electrically converted between U-frame quasi-cardioid and sealed box, with identical free field response. The NaO II RS has only the U-frame cardioid. That should tell you something. The only advantage I found with monopole subs was their greater efficiency so they could play louder. I haven't listened to dipole woofers for several years. They are just too inefficient for a small foot print full range speaker like the NaO II RS.
Also, in this test I am not trying to find optimum position for the placement of the woofers. I'm interested in how they perform in a typical stereo speaker setup.
Old 15th October 2012, 11:09 AM   #400
Banned
Yes please - thank you.
Yes and there are steel bars in front of the windows
The walls at my current place are about 70cm (2.3ft) thick.
Measured monopole and dipole room responsesHide this!Advertise here!
Getting Dipole bass out of a monopole subwoofer Hara Subwoofers 19 3rd January 2016 10:00 PM
Omnipole, monopole, dipole and...nopole?? terry j Multi-Way 25 1st July 2007 03:28 AM
Dipole vs monopole, balls or not ... ? Jussi Multi-Way 11 4th May 2006 03:38 PM
DBX vs BSS vs 24/96 for Dipole/Monopole combo..... gavinson Multi-Way 0 29th November 2005 12:07 AM
Dipole speaker with monopole rear firing midbass? GuyPanico Multi-Way 4 12th November 2005 02:49 PM
