Measured monopole and dipole room responses
Old 12th October 2012, 08:10 PM   #351
gedlee is offline gedlee  United States
gedlee's Avatar
Originally Posted by Rudolf View Post
We are still lacking a controlled, fair and equal comparison, that shows categorically a better modulation reproduction ability of the dipole. Either by theory or by measurement.
Rudolf
And I think that a reliable connection between "modulation production" and listener perception is also lacking. I fail to see why a LF playback wants a a high rate of modulation production (or whatever the measure is). I could give hypothetical rationalizations to say just the opposite.
Earl Geddes Gedlee Website
Old 12th October 2012, 08:26 PM   #352
gedlee's Avatar
Originally Posted by _Wim_ View Post
How do you setup this EQ. Do you start with one sub and EQ all major peaks (leaving the dips alone), then add a second sub and again EQ the peaks, add a third sub...
Or do you use something proprietary?
I have software that does this, not completely automated, that would be complex. This software is proprietary. But the technique is basically what you said - start with the sub farthest from the listener and EQ it to blend in well with the mains (no crossover is used, but the mains generally don't have a very low cutoff). Then add in the next closest sub and optimize. Finally the third, if there is one and so on. With the software, which shows the results in real time, I can converge on a good solution in 15-20 minutes.
This service is only offered to my customers however because I need some value added to sell subs, which are basically commdities and all the same in my book. I think that you can see that I really don't care what kind of sub it is, the technique works with anything. The controller is a DCX2496 or sometimes a MiniDSP.
A room setup this way is incomparable to one in which the sub is simply placed in the room, or one in which the LFs are handled by the mains. After some 40 years of studying the LF sound in small rooms and doing sound system setup, I have concluded that this is the only way to consistantly get great bass in any room. But still, some rooms are better than others, I can see this in the variety of examples that I have done. My room, which has very high LF damping, still comes out among the best. With a lot of LF damping not much is required from the subs, but some control always helps.
Old 12th October 2012, 11:09 PM   #353
mondogenerator is offline mondogenerator  England
mondogenerator's Avatar
Im certainly not up to speed with the Drs in the house, but this thread got me thinking.
Perhaps i repeat others concepts BUT:
Why not turn the ENTIRE room into a bipole?
If you humour me for a minute, imagine front and rear in wall IB subs, wired push pull.
How would the room behave?
With DSP i imagine it would be simple to tune with delay and or phase rotation. Probably im hand waving frantically and its vague at best, but the thought just occurred to me.
Balancing the things I must do, with the things I'd like to do...This is a skill (or a luxury) amongst many that I do not possess.
Old 12th October 2012, 11:12 PM   #354
puppet is offline puppet  United States
I believe that is the premise of a DBA.
Old 13th October 2012, 10:26 AM   #355
markus76 is offline markus76  Germany
Banned
Yes. This is how a DBA works:
Old 13th October 2012, 10:48 AM   #356
a_tewinkel is offline a_tewinkel  Netherlands
I think John K has a similar suggestion (like the push-pull dipole idea) on his website: DP_woofer_room
A DBA is slightly different, since it has a time delay between the front and back array corresponding to the path length between the two arrays. The front array generates an approximation of a plane wave which is then actively dampened by the rear array when it arrives at the rear wall. Thus it creates a pure travelling wave.
It's expensive and relies very much upon room shape and acoustics in order to function properly, which are major drawbacks. It's not practical in most rooms (although it is very cool ).
Old 13th October 2012, 11:15 AM   #357
Banned
This "Opposite Phase-Opposite Corner" configuration was tested in the Fazenda paper "Subjective Preference of Modal Control Methods in Listening Rooms" but it didn't work well in a real room while in theory it should. A DBA seems to be more robust even if the room is not ideal.
Old 13th October 2012, 11:32 AM   #358
Elias is offline Elias  Finland
Elias's Avatar
It is not lacking but you are being ignorant. And it is not production but reproduction that we want.
The perception is everything. It is very easy to just listen to the modulated signals. If you are not able to DIY you can even go and buy Linkwitz's toneburst CD:
Toneburst Test Signal CD
Modulated wavelets are good because you can also play them and listen how they sound with the real speakers in a real room.
If you compare the steady state FFT responses posted earlier, it is near to impossible to tell the perceptual differences from them. And there is a huge perceptual difference between the monopole and dipole when playing signals with modulations. It has become obvious the steady state FFT freq response is useless in describing this.
The modulated wavelet analysis on the other hand clearly shows how the signal behaves, and indicates the big difference between monopole and dipole.
Finally, and most importantly, it correlates very well of what is being perceived.
- Elias
Liberate yourself from the illusion of two speaker stereo triangle
Dipole Bass vs Monopole Bass Stereophonic Sound from a Single Loudspeaker 3 Speaker Linear Stereo Matrix Wavelets
Old 13th October 2012, 12:32 PM   #359
markus and puppet, thanks for the clarification. Its a relief to know that im almost on the same page!
Old 13th October 2012, 04:11 PM   #360
Baseballbat is offline Baseballbat  Germany
I am wondering what exactly do you mean with "modulated wavelets". Do you mean those cosine shaped bursts of Linkwitz?
No, it's not useless, but there are better methods of visualize the same data. That's what you are doing with your wavelet CSD.
But it is not hard to find important differences in your frequency responses. Below 40 Hz both work nearly the same. Then there's a mode at 45 Hz, still both with same level. But the next mode at 50 Hz is less excited from the dipole. Above the monopole seems to produce a null at the measurement position, while the dipole seems to work very uniform. Then, at 65 Hz, there's another very deep null from the monopole, a hint to a long decaying mode*. Above 65 Hz, both are nearly the same again, with the dipole having a slightly deeper null at 85 Hz. And all this is also visible in your CSD, although the modes are not clearly visible. That's because the used wavelets have to much bandwidth to show it. Reducing the bandwidth will give a better distinction of each mode, while sacrificing time resolution.
I would not damn the frequency response visualization. It is well enough for showing the modal behaviour of a room, and much better suited when designing EQs oder absorbers for single modes.
* I once experimented with notch filters placed on nulls, and it was quite successful. The frequency response was much more uniform across different places in the room. The perception at the listening position was not much affected.
Measured monopole and dipole room responsesHide this!Advertise here!
Getting Dipole bass out of a monopole subwoofer Hara Subwoofers 19 3rd January 2016 11:00 PM
Omnipole, monopole, dipole and...nopole?? terry j Multi-Way 25 1st July 2007 04:28 AM
Dipole vs monopole, balls or not ... ? Jussi Multi-Way 11 4th May 2006 04:38 PM
DBX vs BSS vs 24/96 for Dipole/Monopole combo..... gavinson Multi-Way 0 29th November 2005 01:07 AM
Dipole speaker with monopole rear firing midbass? GuyPanico Multi-Way 4 12th November 2005 03:49 PM
