Measured monopole and dipole room responses
Old 8th October 2012, 07:12 PM   #261
Elias is offline Elias  Finland
Elias's Avatar
Originally Posted by Rudolf View Post
I have done that with my earlier dipole speakers. Significant altering of modes will only start if you rotate the dipole at least ~45 against the mode axis. You don't want to switch off single modes, but probably want to attenuate one mode and raise another mode at the same time. Inevitably that led me to a 45 toe-in of the LF dipoles - every time. And it did change the direct sound significantly!
At 45 an ideal dipole should be 3 dB attenuated compared to 0. If you keep the mid/high part of the dipole at 0, you have a matching problem. JohnK discussed that at Power matching
Again the easiest way to solve it is to rotate the mid/high part of the dipole too - which has some advantages in itself. In the end I never had a convincing reason to rotate the dipole LF part independently from the upper part.
Rudolf
I've also done few tests with dipole rotation in the past, and my experience is somehow similar to yours. While rotation can help, why not, in the few cases I tried it the optimum rotation was, be surprised or not, almost the same as the direction of the main speakers i.e. aimed to the listening area.
So at the end it became feasible to just have a fixed panel.
- Elias
Liberate yourself from the illusion of two speaker stereo triangle
Dipole Bass vs Monopole Bass Stereophonic Sound from a Single Loudspeaker 3 Speaker Linear Stereo Matrix Wavelets
Old 8th October 2012, 07:44 PM   #262
gedlee is offline gedlee  United States
gedlee's Avatar
Originally Posted by Elias View Post
I made it with Octave, how else
- Elias
There are lots of ways to do this. I did it in FORTRAN more than 30 years ago and more recently a much bigger model in MathCAD. Octave is hardly the only choice.
Are the actual impulse responses posted somewhere. I'd like to see what they look like.
Earl Geddes Gedlee Website
Old 8th October 2012, 07:59 PM   #263
markus76 is offline markus76  Germany
Banned
Here's the FFT frequency responses of the same impulse responses as before.
This is what you base your opinion upon that dipoles sound better than monopoles? Those responses are both really, really bad. Put a sub directly behind your listening position at shoulder height and get a frame of reference what good low frequency reproduction sounds like.
Old 8th October 2012, 08:09 PM   #264
Wavebourn is offline Wavebourn  United States
Designer & Technologist
Wavebourn's Avatar
Originally Posted by gedlee View Post
And some prefer to hear music the way that it was recorded - you know "Hi-Fi"!
That's why I am going to add some book shelves instead of curtains. Too many curtains for a living room, they cover memory foam mattress toppers on walls.
I would not explain differences of sound of monopoles and dipoles in the room by different frequency response. Dipoles rather somehow blend reverberation of rooms with reverberation reproduced by stereo speakers making kind of more realistic soundstage. But more realistic does not mean closer to real soundstage that was recorded.
Nothing in the universe is perfect. The ideal things are the ones that are most optimal. Optimization criteria, what matters. When I hear "No Compromise Design", I want to take a sledgehammer and test how impact-proof it is.
Old 8th October 2012, 08:21 PM   #265
Elias's Avatar
That was just to show that in an irrelevant metrics they can look whatever they do. Steady state unwindowed FFT frequency response does not correspond how we perceive music signals which are constructed of temporal modulations.
- Elias
Old 8th October 2012, 08:24 PM   #266
Elias's Avatar
What is there to see. Humans do not perceive impulse responses.
Old 8th October 2012, 09:10 PM   #267
Banned
- Elias
If the magnitude response would be flatter then there wouldn't be as many time problems either. Magnitude response is not irrelevant, it's intimately connected to the time domain.
Nobody has said that problems in the time domain are inaudible. Up to this point all you're showing is a very bad monopole response and a very bad dipole response - caught between a rock and a hard place.
Old 8th October 2012, 09:16 PM   #268
Banned
Err, your wavelet analysis is based on impulse responses, no?
Old 10th October 2012, 04:27 PM   #269
soundaatma is offline soundaatma  United States
Seems that this thread is dying once again without reaching any conclusions about the best among : sealed vs cardioid vs dipole, for optimum realistic bass reproduction in acoustically large rooms.
I guess we have to wait for John K to carry out his independent comparisons using Elias's software and methods.
Old 10th October 2012, 05:15 PM   #270
gedlee's Avatar
If you are waiting for a conclusion that everyone agrees to, that is never going to happen.
I have reached my conclusion. I posted it awhile back. Not what anyone wanted to hear, but hey, I not here for fanfare.
Measured monopole and dipole room responsesHide this!Advertise here!
Getting Dipole bass out of a monopole subwoofer Hara Subwoofers 19 3rd January 2016 10:00 PM
Omnipole, monopole, dipole and...nopole?? terry j Multi-Way 25 1st July 2007 03:28 AM
Dipole vs monopole, balls or not ... ? Jussi Multi-Way 11 4th May 2006 03:38 PM
DBX vs BSS vs 24/96 for Dipole/Monopole combo..... gavinson Multi-Way 0 29th November 2005 12:07 AM
Dipole speaker with monopole rear firing midbass? GuyPanico Multi-Way 4 12th November 2005 02:49 PM
