Measured monopole and dipole room responses
Old 6th October 2012, 10:53 AM   #201
markus76 is offline markus76  Germany
Banned
Originally Posted by 6.283 View Post
Every dipole speaker can do this where
a. The sub is "separated" from the rest
b. the sub goes up to your desired F.
To get to the Schröder F (or a little beyond) with reasonable output you might require already 2 drivers per side.
Yes but my point was that it's not done. Being able to adjust mode coupling is one of the biggest advantages of a dipole but it's not utilized. Recognize any of these dipoles?
Old 6th October 2012, 11:11 AM   #202
Rudolf is offline Rudolf  Germany
Rudolf's Avatar
Originally Posted by markus76 View Post
Again, the topic was LF. One can make the dipole null "point" in different directions by rotation. This shouldn't change the direct sound significantly but it will alter the way the dipole couples to modes.
Markus,
I have done that with my earlier dipole speakers. Significant altering of modes will only start if you rotate the dipole at least ~45° against the mode axis. You don't want to switch off single modes, but probably want to attenuate one mode and raise another mode at the same time. Inevitably that led me to a 45° toe-in of the LF dipoles - every time. And it did change the direct sound significantly!
At 45° an ideal dipole should be 3 dB attenuated compared to 0°. If you keep the mid/high part of the dipole at 0°, you have a matching problem. JohnK discussed that at Power matching
Again the easiest way to solve it is to rotate the mid/high part of the dipole too - which has some advantages in itself. In the end I never had a convincing reason to rotate the dipole LF part independently from the upper part.
Rudolf
www.dipolplus.de
Old 6th October 2012, 11:19 AM   #203
Banned
45° is a lot, probably already too much. Did you try different source locations and rooms?
Old 6th October 2012, 11:23 AM   #204
StigErik is offline StigErik  Norway
StigErik's Avatar
I have four separate dipole woofers, where two are located at the sides and almost 90 degrees rotated. This concept works very very well indeed. The resulting response is smooth and free from dips and bumps from room modes.
dipoles dipoles dipoles dipoles dipoles dipoles dipoles dipoles and dipoles
Old 6th October 2012, 11:31 AM   #205
Banned
Stig, if I remember correctly, the woofers are located pretty close to the listening position?
Old 6th October 2012, 11:36 AM   #206
StigErik's Avatar
Well.. sort of. They are placed close to the front and side walls actually.
Old 6th October 2012, 11:45 AM   #207
Rudolf's Avatar
Mainly one room, but dipoles located at the long wall and the short wall. Measured results were different of course, but the conclusion the same for both installments. You find measurements and a discussion (in German) of the short wall version at Dipole und Kontrolle der Raummoden, Lautsprecher - HIFI-FORUM
www.dipolplus.de
Old 6th October 2012, 11:51 AM   #208
Banned
Found the floor plan. Looks like you're listening with an opening angle >60°?
Old 6th October 2012, 11:52 AM   #209
john k... is offline john k...  United States
john k...'s Avatar
Since there is discussion about position I thought I would post this quote from one of my web pages:
Dipole:
Consequences of source position (independent of orientation):
There will be no contribution to the in room SPL from an axial mode aligned with the dipole axis when dipole is centered at a pressure anti-node (velocity node) for that mode.
Additional consequences due to directionality (orientation):
There will be no SPL contribution from any mode in the direction orthogonal to the dipole axis.
Monopole:
Consequences of source position:
There will be no SPL contribution from a mode when placed at a position where that mode has a pressure node.
Additional consequences due to directionality:
Being omni directional, a monopole has no consequences arising from directivity.
Cardioid:
In general a cardioid is not limited by position alone with regards to modal contributions to the SPL.
There will be no SPL contribution from a mode when placed at a position where that mode has a pressure node if it is also oriented such that the mode is orthogonal to the axis of the cardioid.
These are under idealized conditions but give a sense of why different woofer formats behave so differently. Also, recognize that it is a two way street. A woofer may excite a mode very strongly but it will have no effect at the listening position is the listener is sitting at a pressure node for that mode.
Also, regarding separating the main speakers and woofers, that was one of the features of the Mini:
John k.... Music and Design NaO dsp Dipole Loudspeakers.
Old 6th October 2012, 11:54 AM   #210
StigErik's Avatar
It has been changed somewhat since then. The listening angle for the main dipoles is close to 90 degrees, and the side woofer towers are at almost 90 degrees angle from the listening pos. The woofers are closer to the walls as well.
Measured monopole and dipole room responsesHide this!Advertise here!
Getting Dipole bass out of a monopole subwoofer Hara Subwoofers 19 3rd January 2016 11:00 PM
Omnipole, monopole, dipole and...nopole?? terry j Multi-Way 25 1st July 2007 04:28 AM
Dipole vs monopole, balls or not ... ? Jussi Multi-Way 11 4th May 2006 04:38 PM
DBX vs BSS vs 24/96 for Dipole/Monopole combo..... gavinson Multi-Way 0 29th November 2005 01:07 AM
Dipole speaker with monopole rear firing midbass? GuyPanico Multi-Way 4 12th November 2005 03:49 PM
Copyright ©1999-2017 diyAudio
