speaker crossover problem
Old 13th June 2009, 01:58 PM   #1
dayking79 is offline dayking79  United Kingdom
Default speaker crossover problem
i have a pair of speakers that have a faulty crossover (drive unit swapping was done to realise a crossover fault). When connected to the bad crossover, the tweeter is at a very low volume level.
On the crossover there is a potentiometer which i think is the problem but there is also 1 cap and 1 resistor, see list below;
COLVERN 11/135/2531 10RK 1907 POTENTIOMETER
2.7UF 160V 10% CAP
ERG 74 EV 3R3 5% 7842 RESISTOR
My questions are, is it likely to be the pot? Or should i just replace all 3 components? If i can't find exact replacements, what alternatives can i get away with?
Your help is always appreciated - thank you.
Old 13th June 2009, 03:52 PM   #2
Cal Weldon is offline Cal Weldon  Canada
Speakerholic
Cal Weldon's Avatar
Do you have any tools? Even a multimeter and a soldering iron will help. Pull the pot from the circuit and test it. Perhaps snap a pic or two and post them. One from the top, the other, the underside.
planet10 needs your help:
Let's help Ruth and Dave
Old 13th June 2009, 04:10 PM   #3
hi and thanks,
i have lots of tools inc a DMM but i have never tested a potentiometer, how do you?
Old 13th June 2009, 04:26 PM   #4
tinitus is offline tinitus  Europe
diyAudio Moderator R.I.P.
Maybe try to replace tweeter pot/att with resistors
Fore a preliminary try a simple series res should do
Even if not properly done, you should be able hear a result, if any
sometimes we know very little, and sometimes we know too much
Old 14th June 2009, 08:56 AM   #5
PeteMcK is offline PeteMcK
what Tinitus said, pots in crossovers don't get used much and the active surface oxidises; open it up and clean, get the balance you like and then measure both sides of the pot and replace with fixed resistors.
to test, measure ohms from the centre tap to one side, and then to the other (it'll be be in the region of ~1-50 ohms)
Impedance varies with frequency, use impedance plots of your drivers and make crossover calculations using the actual impedance of the driver at the crossover frequency
speaker crossover problemHide this!Advertise here!
Problem with speaker, tweeter or crossover? cchean Multi-Way 2 16th January 2009 10:39 PM
crossover problem(135 kep +XT19td) bartekdg Multi-Way 0 25th October 2007 02:33 PM
combining different speaker wires (weird external crossover problem) Ang Everything Else 2 19th January 2007 08:55 PM
Crossover problem Soldering Iron Subwoofers 2 6th January 2005 01:02 PM
Can you hear the crossover point of a speaker with a well-designed crossover? 454Casull Multi-Way 11 2nd April 2004 05:48 AM
