Hello all,
Since I've been on diyaudio I've built a pair of 3" glass speakers which I'm quite happy about. I think I want to try something bigger for my next project. So far it seems like most people are using kits from zaph, planet10 or linkswitz. I think I've narrowed it down to either the ZDT3.5 from Zaph http://zaphaudio.com/ZDT3.5.html or the pluto from linkswitz. Personally I think the one from Zaph is easier and will perform better? Does anyone have any insight / comments about that design? Also, I've heard issues about "surface moutning" drivers, does that mean I should use a router bit and flush mount them instead? Thanks! |
#3 |
yep, I read that link. Just making sure the opposite of surface mounting is flush mounting. how far down do I have to mount it or is "flush" okay?
#4 |
Flush is okay. Unless the crossover frequency is very high, the small difference in driver location is negligible.
The power of Science compels you! |
#5 |
I've been reading up on 3.5 way systems. Apparently they're not so good for vocals? Maybe I need to reconsider the design? or is the difference another audiophile negligible difference?
#6 | |
Dilletante, tinkerer and beggathoner supreme
If adding a .5 driver in a 3-way system it is only ever been a first order low pass below 120Hz ( I'd go lower but that is a readily available inductor value) I guess it is less common these days with better drivers around but used to be seen in many Japanese speakers, and sharing common box volumes too.
QUOTE" The more I know, the more I know, I know (insert maniacal laugh >here<) NOTHING" |
| Prebuild tips for Metronome F167 Build | AdamThorne | Full Range | 25 | 14th May 2008 09:32 PM |
| Insight request: Parallel 4780 | Crash&Burn | Chip Amps | 12 | 24th February 2005 09:14 PM |
| PS Cap to V- larger than the Cap to V+ | GregGC | Chip Amps | 4 | 1st June 2004 01:50 PM |
| mic pre opamp options NE5532, LM833, LF353.. any insight? | evertestmuse | Instruments and Amps | 1 | 23rd February 2004 01:34 PM |
