Old 10th June 2009, 03:11 PM   #1
Al.M is offline Al.M  Myanmar
Default Inductor measurement
Hi All
Is there a way of measuring or estimating accurately inductors within a speaker crossover without desoldering them from the crossover board?
One way perhaps is to count the number of turns across and deep, check wire thickness and aircore diameter and compare this with any online inductor calculators.
Old 10th June 2009, 03:34 PM   #2
tinitus is offline tinitus  Europe
Default Re: Inductor measurement
Originally posted by Al.M
Hi All
Accurately?
Only with measurements, on out of curcuit component
Even if you can calculate mH value from number of windings, length of wire, winding design, it can change a lot only from how careful the actual winding is done
Estimate?
You may be able to estimate whether its 0.5 or 1mH, 2 or 4mH, 3 or 6mH, 5 or 8mH
Old 10th June 2009, 03:35 PM   #3
DcibeL is offline DcibeL  Canada
DcibeL's Avatar
The most accurate inductor calculator I found online was called Calcoil, but unfortunately when comparing the calculated values to known inductor values that I had on hand, the numbers didn't match closely enough for me to rely on software only for determining inductor values.
I would recommend removing them from the circuit and measuring them. You can find cheap LCR meter on Amazon for something like $25.
The power of Science compels you!
Old 10th June 2009, 09:51 PM   #4
nigelwright7557's Avatar
Hi All
Yo ucan work it out by removing it and putting it in series with a resistor. Apply an AC waveform and work out what the resistance is from how much ac voltage is across teh resistor and the inductor.
http://www.murtonpikesystems.co.uk PCBCAD40 pcb design software.
Old 10th June 2009, 10:35 PM   #5
Ron E is offline Ron E  United States
Ron E's Avatar
Count the number of turns axially and radially and measure the length, outside diameter and core diameter. Post here and I'll give you an estimate.
Our species needs, and deserves, a citizenry with minds wide awake and a basic understanding of how the world works. --Carl Sagan
Science is a way of thinking much more than it is a body of knowledge. --Carl Sagan
Old 11th June 2009, 12:08 AM   #6
DcibeL's Avatar
Default Re: Re: Inductor measurement
Originally posted by nigelwright7557
You can work it out by removing it and putting it in series with a resistor. Apply an AC waveform and work out what the resistance is from how much ac voltage is across the resistor and the inductor.
D'oh! Here's a "Why didn't I think of that!" moment...The things you forgot you learned in school. Simple RL circuit with an unknown.
Copper coil inductor vs. round core inductor tomchaoda Pass Labs 7 21st September 2011 04:42 AM
WTB: Inductor budwiser Swap Meet 1 10th April 2009 06:55 PM
air core inductor vs. iron core inductor WBS Planars & Exotics 5 7th May 2007 11:02 PM
inductor tomes Multi-Way 4 23rd July 2004 02:43 PM
Inductor value? B.VDBOS Multi-Way 2 7th March 2004 10:34 PM
Page generated in 0.08039 seconds (80.28% PHP - 19.72% MySQL) with 10 queries
