Old 10th June 2009, 01:58 PM   #1
David Gatti's Avatar
Default Loads of action over at Scanspeak
Not only have they separated from Tymphany, but check out all their new drivers!
Underhung woofers, fibreglass mids, dome mids, 19mm tweeters, even a beryllium tweeter.
Disappointed though that there isnt more in the 8", 10" and 12" woofer range.
http://www.scan-speak.dk/products.htm
Old 10th June 2009, 02:23 PM   #2
Well that is interesting. Not much new other than teh Dsicovery woofers, but more pulled in other Tymphany lines? Looks like they pulled in the Vifa dome mid and DX and XT tweeters? And the Peerless HDS 810921 is now Scanspeak? Didn't know they built that tweeter since 2005 either.
~Brandon
DriverVault Soma Sonus Old Driver Tests
Old 10th June 2009, 03:31 PM   #3
DcibeL is offline DcibeL  Canada
DcibeL's Avatar
This "Discovery" line is indeed interesting. Includes some Vifa tweeters, the 810921, and a handful of fibreglass cone woofers.
The Peerless and Vifa drivers haven't been removed from Tymphany's site, and I don't see any stores listing them as Scan-Speak, so we'll see how this all pans out. As long as they don't start jacking up the price of the Peerless and Vifa drivers because they carry the Scan-Speak name, I'm fine with it.
The power of Science compels you!
Old 10th June 2009, 03:36 PM   #4
infinia is offline infinia  United States
infinia's Avatar
Interesting, I noted that most of their drivers are 4 ohm now. Car audio or high current amps need only apply.
like four million tons of hydrogen exploding on the sun
like the whisper of the termites building castles in the dust
Old 10th June 2009, 04:09 PM   #5
DcibeL's Avatar
There is an equal amount of 4 Ohm woofers as 8 Ohm, if not more 8 ohm woofers. There are more 4 ohm midrange drivers, but this is not out of the ordinary as moving to a 4 ohm midrange partially makes up for the poor sensitivity, making the driver more useful.
There are a fair bit of 4 ohm tweeters, but I don't think that is a problem for most amplifiers. In any case, if you are in the market for Scan-Speak speakers, I would hope that your amp can handle a 4 Ohm load.
Old 10th June 2009, 04:55 PM   #6
infinia's Avatar
Thanks but Scan Mids and tweets are what I look at mostly, Subs/woofers and even midbass are a little rich for me... compared to vifa, peerless and some of the newer asian offerings. YMMV
Old 10th June 2009, 06:57 PM   #7
jerome69's Avatar
It's a very good news to see Peerless, Vifa products in scan-speak line. In my opinion, scan-speak should keep a very good quality control on these products ?
wiki action paulspencer Multi-Way 2 19th October 2005 12:26 PM
Help me get TT back in action on budget mashaffer Analogue Source 4 25th May 2005 10:59 PM
Bleeder resistor action sam9 Solid State 8 15th May 2003 08:48 PM
Page generated in 0.10144 seconds (74.01% PHP - 25.99% MySQL) with 10 queries
