Old 9th June 2009, 12:45 AM   #1
speedemon's Avatar
Default Crossover Spec Recommendation for DYNAUDIO Drivers???
Hi All
I'm in the works of revamping my crossover to try to refine it somewhat. I looked through all over the net and found some spec sheets on the drivers but no gives any factory recommended crossover points nor any info on setting up these drivers. Does anyone know if DYNAUDIO ever suppied this info? My system consisit of these drivers in each cabinet in a Diapolito configuration:
2 ¨C 30W100 ¨C Woofers
2 ¨C 17W75LQ ¨C Midwoofers
1 ¨C T330D Esotar ¨C Tweeter
Thanks in Advanced!
Art
Old 9th June 2009, 03:45 PM   #2
chrisb is offline chrisb  Canada
Default Re: Crossover Spec Recommendation for DYNAUDIO Drivers???
Originally posted by speedemon
Hi All
Thanks in Advanced!
Art
this is the Fullrange (read generally Single driver) forum - if you haven't already tried, you'll probably get better results at the general loudspeakers forum
you don't really believe everything you think, do you?
community sites t-linespeakers.org, frugal-horn.com commercial site planet10-HiFi
Old 9th June 2009, 03:59 PM   #3
speedemon's Avatar
Thanks, I'll post it over there and see if I can get some results.
Art
crossover for dynaudio D-21, D-54 and 30W54 set Filip89 Full Range 0 8th August 2009 04:58 PM
Anyone got spec's on the '70's Isophon drivers. Shoog Full Range 9 1st May 2009 12:24 AM
Enclosure recommendation for cheap drivers asvisn Multi-Way 9 22nd July 2008 12:52 AM
recommendation for variable crossover (wtb) hum4god Subwoofers 3 2nd February 2008 03:13 PM
old dynaudio crossover design george a Multi-Way 2 13th August 2006 07:19 PM
Page generated in 0.06996 seconds (67.90% PHP - 32.10% MySQL) with 10 queries
