Old 7th June 2009, 07:13 PM   #1
Default crossover mounting in small volume monitors
I was wondering how crossovers should be mounted, in particular in small monitors (in my case Zaph's Bargain Mini ZBM4). In this image, it's clear that he first lays the damping and so the crossover must go on top of the damping (unless he places the crossover externally, but that doesn't seem the case since there is only one set of speaker terminals on the inside). However, most crossovers I've seen have their electronics laid out on a thin piece of hard board. I would think that if you put this on top of the damping, it will surely cause reflections, which is the whole point of using damping. On the other hand, if the crossover were to be placed underneath the damping, that would change the cabinet dimensions? Anyway, any advice?
WTB: Volume Potentiometer Mounting Board nic6paul Swap Meet 1 31st March 2009 01:28 AM
Small diy monitors - two way or coaxial? wxn Multi-Way 7 12th June 2006 02:56 PM
Small Monitors, Small Room Seth Smith Multi-Way 0 30th January 2006 05:01 AM
Mounting small speaker in 3/4" baffle Dave Jones Multi-Way 6 21st August 2004 01:14 PM
mounting small pincushion (square) frame drivers? Stephen D Multi-Way 5 12th April 2004 05:04 PM
Page generated in 0.07048 seconds (63.22% PHP - 36.78% MySQL) with 10 queries
